Power center upgrade
Sixfeetofmud
Hi all,
Just bought a used truck camper and the power center/converter/charger doesnโ€™t work and needs to be replaced. I attached a pic of the details. I am wondering if the Wfco WF-8725 would be a suitable replacement. Specs attached.
***Link Removed***
***Link Removed***
9 REPLIES 9
StirCrazy
Navigator
Navigator
i had a old one with 3 glass fuses and one reset button. strait from 1991. I did have to cut the opening a little bigger but it wasn't a big deal. I think I did a post with pictures in the diy forum or the camper forum.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Sixfeetofmud
StirCrazy wrote:
I used this one for my upgrade.
https://www.amazon.ca/Progressive-Dynamics-0318-4135-Inteli-Power-Converter/dp/B01EXKUA3E/ref=sr_1_5?keywords=PD+power+centre&qid=1590406796&sr=8-5
Steve
Did you also have an allanson D-20-BRA-A ? That PD 4135 looks like a nice unit.
BFL13
Made in Winnipeg!
https://www.usedvictoria.com/classified-ad/RV-Power-Converter-_35827347
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
enblethen
I would call Best Converter
It maybe possible to get a direct lower section.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wa8yxm
I too suggest the Progressive Dynamics. Made in the usa (From I'm sad to say mostly imported parts) it is a proven performer and I really like the way it is factory programmed.
The 4600 series is designed to replace the electroics on your WFCO. you use teh same breaker and fuse panel. but the back part (The "Guts" get replaced.. I'm on my 2nd one. first lasted over 12 years.
StirCrazy
Navigator
Navigator
Steve
2016 Cougar 330RBK
Lynnmor
WFCO has a poor reputation, find another brand if possible. You can get good advice from Best Converter, have your current model information available when you call.
Sixfeetofmud
https://www.amazon.ca/photos/share/7cxrkzSI6Rqxz6CL6EJr2EU08RoGpPNhjJ4YZ9Rh9vE
Sixfeetofmud
https://www.amazon.ca/photos/share/rb5jwvO2GjBKRy3RhaGPtgDZv6KGXAiBfOtFADiKv78
