โJun-19-2020 06:31 PM
โJul-28-2020 10:44 AM
Bud
USAF Retired
Pace Arrow
โJul-28-2020 10:07 AM
enblethen wrote:
Is there room to put it inside battery box?
Coat terminals with electrical grease
โJul-28-2020 08:04 AM
Bud
USAF Retired
Pace Arrow
โJul-28-2020 07:53 AM
โJul-27-2020 06:53 PM
enblethen wrote:
I would replace it with a new auto-resetting circuit breaker. Make sure it is protected from water including road spray.
โJul-27-2020 10:09 AM
โJul-27-2020 09:34 AM
Bud
USAF Retired
Pace Arrow
โJul-27-2020 07:49 AM
โJun-22-2020 05:30 PM
Gjac wrote:
Another thing to check is the set screws that hold your 12v wires in place on either side of the 12 v fuses a loose screw could cause an intermittent problem.
โJun-22-2020 04:39 PM
โJun-22-2020 02:29 PM
Jetstreamer wrote:
I donโt necessarily think they are implying your batteries are bad itโs just that your voltage readings are of no help in trying to diagnose the problem with a solar charger in the loop.
โJun-22-2020 05:34 AM
โJun-21-2020 04:32 PM
KD4UPL wrote:
Are you sure your batteries are good. Your voltage measurments are useless because your solar charger is holding the voltage up. Batteries do not have a resting voltage of 14.2, that is under charge of some kind. In fact, 12.8 is a little high for resting voltage. A fully charged 12 volt battery at "rest" will only read 12.7 volts. With a little load it will always be below 12.7 volts if there is no charging source present.
Unhook you solar charger, unplug from shore power, then measure your voltage with and without a load.
โJun-20-2020 04:08 PM
