โJun-11-2017 01:01 PM
โJun-15-2017 04:02 AM
โJun-14-2017 08:46 PM
โJun-13-2017 08:32 AM
JimK-NY wrote:
If you are a full timer, you probably use the generator and do not need to drain the gas. If you are not a full timer, what do you do about snowblowers, weed whips, chain saws, lawn movers and leaf blowers? I use stabilizer and have not had any issues. I always use stabilizer even if I do not plan on storage.
โJun-13-2017 06:31 AM
โJun-13-2017 04:20 AM
JamesJudasPriest wrote:
I don't know about why this is important?
My honda 2000 with a drained carb starts in 2 pulls after storage season?
โJun-12-2017 01:42 PM
โJun-12-2017 12:53 PM
โJun-11-2017 06:52 PM
Lynnmor wrote:
The procedure outlined by Leroy should be modified somewhat.
Cap vent CLOSED.
Engine switch ON.
Shake side to side.
Cap vent OPEN.
Choke ON.
Pull rope till it starts.
โJun-11-2017 06:44 PM
โJun-11-2017 05:09 PM
โJun-11-2017 02:38 PM
Snowman9000 wrote:romore wrote:
You can open the drain valve until clear fresh gas comes out, close it then pull normally.
Are you sure? It has a fuel pump. I would think the only way is to pull and pull. Other than to pressurize the tank, or to squirt a little some into the carb inlet.
โJun-11-2017 02:31 PM
profdant139 wrote:I know because I can hear it try to start even on a slow pull. Then I fast pull.
How do I know when to switch from long slow priming pulls to fast hard starting pulls?
โJun-11-2017 02:25 PM
โJun-11-2017 02:07 PM
