Propane grill
Busdriver
If you have a grill that you use the one pound bottle with. When you convert it to use a portable hose from your 30 lb tank how do you regulate the heat, because you have to remove the regulater because that is the part the bottle screws into
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
8 REPLIES 8
ng2951
What red31 said.
Foard County News & Sassy Schoolmarm
with Chloe, Belle, & Danke
2017 GD Imagine 2800BH
2017 53 days camping
'07 GMC Sierra 2500HD Classic 4x4 LBZ Duramax Diesel
Honda 2000sThe Bayou Bounty Hunters Cowboy Club
The Single Action Shooting Society
azdryheat
The regulator on my Weber 2000 grill wasn't working so I modified it. I got a 5' hose w/ regulator to connect a 20# propane bottle to the grill, after removing the Weber's regulator.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
IAMICHABOD
naturist wrote:
With that type grill, you need an adapter hose, $16.95 from Lowes or Home Depot. It's 4 feet of hose with a fitting for the 20 pound tank on one end and a fitting that screws into the 1 pound can receiver on the grill regulator.
You can get them from Amazon too.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Snowman9000
The hose screws into the same port that the bottle does.
Currently RV-less but not done yet.
naturist
Tvov
There are a lot of different connections, adapters, and hoses available for propane tanks and grills. It is possible you just haven't found the correct adapter. If your local hardware store sells propane grills, they may have some different adapters you can look at.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
red31
unregulated propane from a container just requires the proper hose, no need to remove the reg.
To connect to regulated low pressure propane, some grills need a new valve like this http://www.camco.net/product/lp-gas-control-valve-wquick-connect-10654/
each grill is somewhat different in how to converter from container pressure to regulated low pressure.
accsys
The regulator and volume valve are two different things on my Coleman grill.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
