Propane tank
LOFAT36
I have 2 30 lb. tanks on my TT. One started hissing when turned on so I switched tanks and no noise. After about a week I switched back to the noisy tank and there was no noise. So a few days later I unhooked from shore power and the fridge switched to gas and the tank started hissing again. What’s with that ?
12 REPLIES 12
72cougarxr7
I has one that was leaking, it ended up being one of the pigtail hoses.
Replaced and has been fine for a while now.
enblethen
Did you try reversing hoses on the tanks to see if noise moves to other tank?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
LOFAT36
SidecarFlip wrote:
Regulator noise? Mine makes noise when the flow is heavy, I ignore it.
. Could be that. It’s more of a whistling sound than a hiss.
Yosemite_Sam1
downtheroad wrote:
More info...is it actually leaking propane. Did you do a soapy water test?
I use a lighted match test, lol.
enblethen
Would the regulator not make noise on both tanks?
Bud
USAF Retired
Pace Arrow
DutchmenSport
SAR Tracker wrote:
SidecarFlip wrote:
Regulator noise?
That's what I was thinking also.
Agree. When I run my furnace the regulator sounds like a tea kettle steaming. It only does that when the furnace is running. High volume demand when it whistles. Nothing to worry about.
SAR_Tracker
SidecarFlip wrote:
Regulator noise?
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
SidecarFlip
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
enblethen
Noise could be coming from the excess flow hose pigtail.
Try physically switches hoses between the tanks.
Bud
USAF Retired
Pace Arrow
Dr_Jay
I agree. Once you locate the leak we can help diagnose the problem. Is there a smell of propane and//or your propane alarm is sounfing off? When in the least amount of doubt of a leak shut of the system entirely until it is repaired. .
2013 Winnebago Sightseer
Greater Boston Area
2oldman
Mine hiss (leak) when they're overfull and hot.
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
