โJun-27-2016 05:46 PM
โJun-28-2016 10:15 PM
rjxj wrote:SFVdave wrote:
I have my panels and cable. I'm still waiting for the mounts and controller and fuses. Went up the ladder today and removed the vent cap, Re-ran the fishing cord over to the corner. Have any of you drilled 2 holes in the vent base vs cutting the wire mesh. Seems the mesh could end up abrading to cable. I was thinking of sliding rubber insert washers on the cable and set them in the side of the base. Am I over analyzing this?
I put something like this in the side of the vent base.
โJun-28-2016 08:11 PM
โJun-28-2016 06:58 PM
โJun-28-2016 01:17 PM
Darryl&Rita wrote:grizzzman wrote:SFVdave wrote:
I see most route their solar cables down the fridge vent and do so on the side opposite the flue. Is there any concern for the amount of heat generated by fridge, especially on a HOT sunny day. I was told the heat will add resistance to the cables and they will deteriorate quickly and can cause failure of the cables, panels or controller.
Any thoughts?
I used PVC water pipe to protect the wires from direct contact and heat. I had no issues due to heat.
Good luck!
PVC has a lower temp rating than a good quality (temp-wise) wire. Keep both of them away from the flue. Also, being in a conduit lowers the temp rating of all wires vs. open to air.
โJun-28-2016 01:08 PM
YC 1 wrote:
Use low voltage landscape wire and you will have plenty of abrasion and heat protection as well as UV. It is nice and heavy and works extremely well. Available at any home improvement store in the landscape lighting area.
โJun-28-2016 12:32 PM
โJun-28-2016 09:04 AM
โJun-28-2016 02:47 AM
โJun-28-2016 02:05 AM
โJun-27-2016 08:16 PM
โJun-27-2016 08:13 PM
Any thoughts?
Good luck!
โJun-27-2016 07:53 PM
โJun-27-2016 06:32 PM
โJun-27-2016 06:31 PM
