Jul-12-2021 08:35 PM
Jul-14-2021 07:02 PM
southernsky wrote:
Make sure all your hydraulics are retracted...slides in and leveling system is up. Then check level. Our Lippert system uses auto trans fluid.
Jul-14-2021 12:41 PM
Jul-14-2021 11:21 AM
Jul-14-2021 11:19 AM
Jul-14-2021 10:18 AM
Jul-13-2021 12:23 PM
RHasse wrote:
ATF has a very distinctive odor, you should be able to recognize it pretty easily. if you aren't familiar with it, just check the transmission dipstick on your car. Take a wiff of that, that odor is very distinctive, hard to miss even if you have a bad sense of smell.
Also, this isn't a very demanding application, it's not like its a tractor digging or moving dirt all day long; it's not going to make a huge difference what you use. There is not a lot of danger in mixing common oils like this, the additive chemistry may not be a perfect match, but there shouldn't be a problem with negative reactions occurring if you added ATF into a system originally filled with anti-wear hydraulic oil, or vice versa. The important thing noted in a message above is DO NOT USE BRAKE FLUID!. Brake fluid is a particular type of fluid that if you added it into your leveling system it would damage the seals and you'd have to have the entire system rebuilt.
Jul-13-2021 09:34 AM
Jul-13-2021 08:32 AM
ChuckSteed wrote:
If the fluid in the Lippert level up is clear it is NOT transmission fluid…
It is AW32 hydraulic oil.. nit all Lippert level up systems come from factory with Red ATF.. it depends on the builder and what they use..
My 2014 Keystone Alpine has clear fluid and is most certainly AW32..
Jul-13-2021 08:29 AM
Jul-13-2021 06:57 AM
Jul-13-2021 06:42 AM
Jul-13-2021 06:03 AM
Flute Man wrote:
For the slides a clear hydraulic fluid would be best in case it leaked inside the rig before the landing gear should not make much difference. Any good loyal label as hydraulic Would be fine.
Jul-13-2021 05:11 AM
Jul-13-2021 04:52 AM
