Raptor 3814 Power Converter
DavidM49
Hi all,
I belive the OEM power converter on my 2007 Raptor 3814 is failing again. Moved it this weekend to our new house, plugged in shore power as always and it sounded like my converter was getting hit with a hammer. Works fine with gen set running. I think my converter is located inside panel just inside the smaller basement door. I have read the Progressive Dynamic equipment is the way to go. Is this just plug and play after I take the panel compartment off? I think I may drill some holes in the compartment to allow for better cooling. Maybe it is just the OEM converter, but this is the 3rd time I have had to replace it. Thinking I can do it myself. Thank you.
Big Dave
2008 F350 Superduty 6.4 TD "Bumbles"
2007 Raptor 3814
2004 Sportsman 700 EFI
2006 YZ125 with 144 Athena Big Bore kit
2008 YZ 85 Supermini 112 Athena Big Bore Kit
2012 YZ250F
2008 KLX450R (Hulk)
2004 DRZ125 pit bike
2 Boys one speed
2 REPLIES 2
09FLSTC
Call Randy at bestconverter.com You didn't say which one you have and that is the first question they will ask. Don't care about RV model, its irrelevant, just converter make and model.
MEXICOWANDERER
Everyone says Randy at BEST CONVERTER is the in-the-know person to talk to.
