โSep-13-2016 07:24 PM
โSep-16-2016 09:06 PM
โSep-16-2016 08:10 PM
โSep-16-2016 07:21 PM
โSep-16-2016 05:16 PM
โSep-16-2016 01:39 PM
pianotuna wrote:
Hi Singleminded,
Does it beep or just flash when there is a problem?
Do the sensor batteries let you know when they need replacement?
โSep-16-2016 11:11 AM
RAS43 wrote:
I have had the Pressure Pro system for 9 years, with 10 sensors on my truck, 5th wheel and boat trailer. Had 1 sensor fail 3 years ago but no other problems and original sensors have the original batteries. I do not full time so sensors come off for the 4 months I am at home. Service has been great when needed.
โSep-16-2016 10:36 AM
โSep-16-2016 03:39 AM
โSep-15-2016 10:26 PM
loggenrock wrote:
Hi Don - been running TST system for almost 10 years, close to 100k miles. Dependable, great customer service, has saved me 3 times so far. ST
โSep-15-2016 06:22 PM
โSep-14-2016 07:44 PM
cmeade wrote:I have the flow-through design and I would not bother if I did it again. The flow-through sensors have a lot of air restriction and adding only 5 psi is quicker if you take the sensor off, add air, and put the sensor back on than if you use the flow-through to add air. It would be a great feature if there weren't so much restriction.
We have the TST 507 non flow thru due to problems I heard that the flow thru have. It only takes a few seconds to remove the sensor with the tool to add air. The TPMS has been great for about 5k mi towing. Would recommend getting sensors for spare tires on TV and towed unit and think sensors for airbags is overkill. TST 507 can handle 22 tires if needed.
โSep-14-2016 06:52 PM
โSep-14-2016 04:12 PM
โSep-14-2016 12:04 PM
