Hello, folks,
I have a 30-lb. propane cylinder that has a bad gasket/O-ring that is causing a leak. This is the seal that the nose of the fitting presses into and seals against. (It is the newer OPD valve on the cylinder, with an Acme fitting on the pigtail hose).
I've searched for a replacement and can only come up with replacements for fork lift systems, which I don't think are the same thing.
Are these seals universal, and are they available to the average person?
Safe travels!
Regan
2003 F250XL 4WD 7.3L Crewcab LB, 6 speed; Prodigy brake controller; Big Tex grille guard/ deer deflector. Canoe hauler and camping truck extraordinaire!
2003 Layton 242 Scout- Extra batteries, solar panels, LED lighting, and propane for boondocking.
