Right LED tail light staying on
Carrera_man
Here's an unusual problem that has cropped up in the past week. Can't get my right LED tail light to shut off. The trailer is not plugged into my truck. The only way I can get it off is to disconnect the house battery. I thought 12 volt house current is separate from truck 12 volt. I did hook it up to my truck and all lights work, except still can't shut off the right rear.
Its not as bright as it normal would be, almost like its picking up residual current from something. The right LED taillight is the only light that has this problem Any ideas?
2008 Chevy 2500 Crew Cab 6.0 gas, 2013 Audi A5 Q, 2013 VRV 26FB Toy Hauler by Livin Lite , Triumph 1200 Explorer
21 REPLIES 21
enblethen
Easy fix and not to expensive to buy new connector.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wnjj
That's great news that you've found it. Thanks for getting back to the thread and not leaving us hanging like so many do.
Carrera_man
Well I believe I found the problem. As some of you have suggested the problem is in the seven way plug. Checked the terminals, the right light was getting 4 volts. Sprayed the plug with DeOxIt electrical contact cleaner. Rear light got very dim, voltage went down to 2 volts. Rapped the plug a bunch of times against the frame, light went out, voltage went to zero. This plug is a molded plug onto the wire so that's why I couldn't take it apart. I suspect moisture get into it one way or another creating corrosion. We had a tough winter here this past year and it pretty much stayed below freezing for about 8 weeks. When our thaw happened last week is when the light came on. I'll replace the plug in a week or two just for the heck of it and cut the old one apart to see if I could find what problem was. A big thank you to everyone for taking the time to give me your opinion!
beemerphile1
Probably a stray strand of wire in the seven-way connector.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
enblethen
Dusty: You could have some poorly insulated connections or corrosion in lamp sockets or trailer connector allowing for slow drain on battery.
Bud
USAF Retired
Pace Arrow
Bobbo
You need a diode to restrict the current flow of the charge line to one direction, toward the battery.
Bobbo and Lin
Dusty_R
Different problem but might be the same.
I have a 20' flat bed trailer with break way brake system with it's own battery. That system charges it's battery when in use. But for some reason it will drain it's battery when sitting, not plugged in and sitting for a long time. I have to remember to unplug it's battery when not in use. Then remember to plug the battery in when I use it.
Before I had a smaller trailer with break away brakes, but it did not have the charging system and it never drained the battery between uses.
Dusty
MEXICOWANDERER
Artum Snowbird wrote:
enblethen wrote:
I would check your connector to the TV on the trailers umbilical cord. You may find corrosion between the 12 volt line and the right "brake" light.
The other place other than wiring is the junction box where the umbilical cord connects to the trailer wiring.
I agree with this diagnosis. The 12 volt feed is right next to the right turn/brake feed. LED's take so little current that the opportunity to sneak across if the insulation breaks down is quite likely.
Mee Three
RLS7201
Carrera man wrote:
RLS7201 wrote:
What you are experiencing is an electromagnetically induced voltage. I had the same problem on my MH when I added LED tail/stop lights. A little resistance between the hot leads and ground will bleed off the induced voltage. I added a 912 incandescent bulb to each side behind the tail lights to bleed of the stray voltage. In my case the stray voltage caused the cruse control and torque convert clutch to malfunction.
Richard
95 Bounder
LED's came with this trailer. Trailer has been sitting plugged in since the end of October. Problem didn't start until last week and only on the right taillight. I would agree with those here if more then one light was effected about a ground or stray voltage. It sure does sound like, as some have commented, that its a problem in the cable going to the truck or the box that cable is connected to. That will be my first place to start.
I stand corrected. I misread your original post.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Carrera_man
Richard
95 Bounder
RLS7201
Richard
95 Bounder
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Carrera_man
Great info here.
I'll check these suggestions this weekend, hopefully the weather will be decent enough for me to do so.
Thanks everyone, I'll post what I find.
wnjj
This guy was having the same issue (but without LED) lights. Like his, I'm suspecting an issue in the 7-pin plug. In your case, it only takes one loose strand of wire to touch the 12V pin and light up an LED bulb.
The power for the turn and tail lights normally comes only from the TV but the connector also has the 12V charge wire from the truck which is connected to your trailer battery.
Artum_Snowbird
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
