โDec-11-2018 07:18 PM
โDec-31-2018 06:07 AM
SoundGuy wrote:TurnThePage wrote:
I guess I'm just looking for advice or a bit of wisdom.
One winter a mouse (and perhaps his family) got into the camper and apparently wintered in 2 of the 5 lengths of ducting. I discovered this when I first started up the furnace in the spring :E but thought I could simply clean them out. Not a chance, I ended up having to replace the affected ducting with brand new - that turned out to be not a difficult task at all because it was all above floor. Had this been underfloor ducting this job would have been a nightmare as I'd have had to first remove the Coroplast to get to the ducts. :M
โDec-12-2018 09:42 AM
DutchmenSport wrote:
My last camper was an Outback 298RE travel trailer. It had a "Polar Package", whatever that means.
I always winterized as normal, but we'd continue using the camper without water in the tanks or lines in some pretty cold weather.
What I found out pretty quick, was the air ducts are designed somehow, to keep the underbelly warm because the water lines ran right next to them. And it seemed to use a LOT of propane. Floors always felt warm when the inside of the camper seemed to struggle, and the furnace would run constantly.
Well, considering the water lines had nothing but RV antifreeze in them, I got a little creative. The furnace was located under the refrigerator and I removed the intake cover and saw it had 3 wire-plastic ducts coming off. I ended up removing one of them, the one that led to the bedroom, as we maintained an electric heater in there. And then I did not replace the intake cover.
What happened was, the open duct port could now blow directly into the camper living space, and this simple change, changed everything. The floor was not as warm any more, and the inside of the camper warmed up much faster and much more. The furnace ran less, and we used less propane. It was a win-win. And yes, this was a 35 foot TT.
Anyway, it's just something to consider, change the air duct so the furnace blows air right at the furnace and really, doesn't go through duct work under the floor at all.
It sounds like you don't need the underbelly duct work for keeping the pipes from freezing, so this may be an alternative.
Anyway, this worked for us for 5 winters.
โDec-12-2018 07:11 AM
โDec-12-2018 06:48 AM
โDec-12-2018 06:22 AM
โDec-12-2018 05:56 AM
โDec-12-2018 05:11 AM
โDec-12-2018 03:13 AM
โDec-12-2018 02:40 AM
โDec-12-2018 02:13 AM
