Running AC on battery power
drillagent
For those days when the pets have to stay in the RV, and the CG charges extra for electricity. Is it safe to unplug the shore power while you're out while leaving the AC on for the pets and then plugging back in when you return? Or will the batteries drain before the end of the day?
TV: 2012 F250 CC SB SRW 6.7L Diesel w/air lift suspension
CHU: 2012 Keystone Montana 3750FL
Hitch: B&W Turnover Ball w/ Companion 3500
Family: Me, HH6, a Boston Terrier, a Shiba Inu
26 REPLIES 26
WI_Bowhunter
Just curious that you can plug in at night, but not during the day...Doesn't the campground charge the same rate weather you plug in all day or just at night?
Keep the Shiny Side Up!;)
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
wa8yxm
Crrier Air V 13,500 btu draws 13.5 amps at 120 volt, that is roughly 135 amps at 12 volt.. I have about 420 amp hours of battery at the 20 hour rate at 135 amps they might last 10 minutes. no more.
skipnchar
EVEN if you install a HUGE inverter for the task, unless you carry four or five hundred pounds of batteries you won't have any luck. If you DO have sufficient battery power you better match it with a HUGE battery charger or plan on taking a month bringing them all back to full charge.
Over all, just not practical. Remember dogs and cats didn't HAVE access to air conditioning until about the mid 50s so they managed to survive very well without that convenience (just as their owners did)
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
JiminDenver
Far cheaper just to pay for the juice from the pole
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
mena661
MEXICOWANDERER
1,560 v/a (per hour)
139 amp hours unreachable level of efficiency
End of day 8 hours?
139X8 = 1,112 theoretical amp hours
Battery discharge limit 50% means a 2,224 amp hour battery bank
(20) golf car batteries
And this is just theory. Now comes inverter losses, and the rest of reality.
Won't it be fun trying to not melt the campground grid trying to recharge those 20 batteries? Oops I forgot. Reality. THIRTY batteries would be more like it.
tvman44
Not at all feasible to run A/C on batteries. ๐Ÿ˜ž
Papa Bob
Husky 16K hitch, Tekonsha P3,
drillagent
Rgr, got it. RV must be plugged in to use AC. Thanks for the help. This is why I love this forum so much.
Old-Biscuit
IF you are leaving pets in rig unattended.......at least provide them with A/C.
Pay the extra cost.
Don't know what type/size/number of batteries you have OR IF you even have an 'inverter' but I doubt you have more than two 12V batteries in your FW.
Soooooooo.......No 120V AC power then no Air Conditioner.
M_GO_BLUE1
You AC needs electricity...period
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Trackrig
No, your batteries simply won't handle it for more than a few minutes if the AC even turns on. Your invertor can't handle the load either. Don'teven try it.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Terrydactile
The AC will not run without 120 volts.
Scott & Theresa Boyd
2 Daughters (Cassie & Brittany)
1 Furkid (Ella, a Basset Golden mix)
2008 Keystone Passport 280BH
2013 F 150 Supercrew EcoBoost XLT
