Shore power issues:(
REDRAT
Hello all
I have an issue with my power, and go figure, we are heading out on vaca next week. When plugged into shore power (battery disconnected) my power cuts out and turns back on constantly. I know the power shuts off completely b/c the LP detector chips each time. I hooked the battery up and the lights just flicker. I have been running a small dehumidifier for the past three weeks with no issue plugged into shore power and no battery. A buddy said the battery has to be hooked up for it to the converter, even when the shore power is connected. My question is did I kill my converter or is this maybe a grounding issue? I have a 2003 26' Fleetwood QS.
14 REPLIES 14
Bobbo
RobWNY wrote:
For what its worth, if your camper has a built in battery shut off, the Propane detector might be draining the battery. When we bought our new 5th wheel, we were told during the PDI that the Battery Shutoff, isn't a total shut off. The Propane detector still draws off the battery.
My new 2017 Airstream was like that. The propane detector and the inverter stayed connected even if the disconnect is activated. I moved the wire for the propane detector to the fuse box so it is now disconnected by the switch. I put a manual disconnect on the inverter because it draws significant power even when not "turned on."
Bobbo and Lin
RobWNY
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
westend
REDRAT wrote:
westend wrote:
On and off suggests a self-resetting DC breaker is at play. But shore power is on, so what DC load could be over-loading that breaker for amps?
A bad or totally depleted battery may draw more than what the circuit breaker can handle. Charge the battery disconnected from the RV with a manual charger, have it load tested. If it tests OK, connect it and try your shore power again.
The Battery is new, but it looses power when the battery is not hooked up. It only flickers when it is hooked up
Do you have a hand held meter to measure voltage?
'03 F-250 4x4 CC
fischer
Lights should work without battery the old converters needed a battery
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
BFL13
The LP alarm will not chirp if there is no 12v at all. It chirps at first when the voltage gets too low, then won't do anything. So you are still getting a little 12v from somewhere, probably the batts.
With your multi-meter, what is the voltage at the battery posts when shore power is not plugged in?
With the batts disconnected, shore power on, what is the voltage at the DC panel lugs?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
PowerMax MBA replacement $150
Progressive Dynamics MBA replacement $193
Call Randy to verify that one of these is compatible.
Do your battery and RV a favor and do not buy a WFCO replacement.
REDRAT
REDRAT
And thanks to you guys for the RAPID replies!!
REDRAT
Its a World Friendship Co Mod # WF-8945AN-11
westend
'03 F-250 4x4 CC
Lwiddis
Delete
time2roll
No, the converter should supply a steady 12 volts without a battery.
Yes, the converter is probably shot.
May as well post the converter model number for best suggestions. And do you camp off-grid wanting a fast charge from the generator?
BTW what is the battery voltage as it sits disconnected?
REDRAT
On and off suggests a self-resetting DC breaker is at play. But shore power is on, so what DC load could be over-loading that breaker for amps?Nothing really, a few LED lights. I turned the breakers off for all the other big ticket items. Left the main 30 amp and the house 15 amp breakers on.
Is there an inverter in the mix? No the panel only says converter. Does the inverter draw too much DC 12v even though there is 120v from shore power?
BFL13
Is there an inverter in the mix? Does the inverter draw too much DC 12v even though there is 120v from shore power?
Photo in Profile
