Shurflo pump switch!
Fredzo
I'm an Electrical Engineer, and have a bad pressure regulator switch on my Shurflo water pump.
I looked all over the net to find the switch, but could only find the complete head assembly for over thirty bucks!
I found the (almost) same switch at Allied Electronics for less than two bucks!
The "almost " part is that it has a normally open contact that can easily be broken off with a pair of pliers.
This switch has a rating of twice the original, and fits perfectly!
Allied P/N: 7120159.
2005 Georgetown 342DS XL
1989 Wrangler Sahara Toad
2005 Liberty Renegade Toad
Blue Ox Tow Bar, Brake Buddy
Retired on Jan 1, 2010!!!
5 REPLIES 5
SCVJeff
Old-Biscuit wrote:
SCVJeff wrote:
As well as the model pump
2005 year RV so if water pump is OEM it is probably one of their 'discontinued' models (Classic Series or Extreme Series) making it difficult to find replacement parts (N.O.S. only)
10 yr old water pump.....upgrade to 4008 Revolution or 4048 High Flow
4008 Revolution----$60
4048 High Flow---$142
Did that and hated them so bought a FloJet. In the meantime I still have a brand new Extreme that might be pressed into service some day.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
RJsfishin
How much trouble can one go thru for $30, or even $60 for a complete pump that normally serves trouble free for 10-20 yrs.
Yes, the question seemed to be about the money.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Old-Biscuit
SCVJeff
Jeff - WA6EQU
DFord
Would it be possible for you to share the link to the switch's page? I tried searching Allied's site without any luck.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
