Oct-22-2015 10:55 PM
CB
Channel 17Redneck Express
Oct-23-2015 02:49 PM
Chris Bryant wrote:
If you only have a short distance to go, I would make it using corrugated plastic sign board, available at Office Depot, and line it with Reflectix.
Otherwise, you could just build a nice ceiling assembly out of wood.
CB
Oct-23-2015 12:29 PM
Oct-23-2015 10:12 AM
LarryJM wrote:JoeChiOhki wrote:
Hey all, I'm having a bit of trouble locating a source for the narrow rectangular aluminum ducting that is used (usually in the ceilings for A/C units) in RV HVAC systems.
I'm in the process of restoring a 40 year old RV, and am adding a roof A/C unit. The used A/C unit I ended up obtaining is designed for ducted use (though it can be run with a straight down discharge), and since I already plan to take down the interior ceiling, and figured it would be a good time to route a duct line over into the nearby cabinets so I can add A/C ducting around the unit instead of just freezing us out in the dinette :).
Thanks!
Do you have the A/C discharge plenum specific to the A/C unit you obtained for ducted installation. Improper installation can cause all sorts of issues such as evap freezing up, poor cooling, etc. This includes very specific duct sizes and min number of registers again of a very specific size.
Larry
4X4Dodger wrote:
Why dont you try to find a wrecked newer travel trailer in your area and salvage the duct work out of that?
CB
Oct-23-2015 09:23 AM
Oct-23-2015 08:44 AM
Force Flow RV cool duct product is a leading brand in the RV market and provides secure and optimal air flow. Our polystyrene product is a proven product in the RV markets and provides easy installation. Remember to look for the Force Flow name to make sure you have the authentic and reliable RV cool air ducting product.
Oct-23-2015 05:29 AM
Oct-23-2015 05:01 AM
Oct-23-2015 04:47 AM
Oct-23-2015 03:52 AM
Halmfamily wrote:
When my father owned his HVAC company he had to form all of his rectangular metal duct work. You might want to call some local metal fabricators who have a break and see if they can make it for you.
Later in his career he switched to insulated duct board which he could fabricate on sight and was already insulated. Much easier to work with. You can get that at a local supply house or Graingers.
Oct-23-2015 03:21 AM
Oct-23-2015 03:08 AM
Oct-23-2015 02:22 AM
Thanks!
Oct-23-2015 12:04 AM
Old-Biscuit wrote:
Contact Heartland and inquire????
CB
Oct-22-2015 11:56 PM
