Spare wiring behind Microwave
MrWizard
Moderator
Moderator
Doug ? Anybody ?
Know what these unused wires are for, Red Black pair appear to be for D.C. power, Microwave quit working, i removed it for replacement and found these spare wires, not a good spot for solar wiring too the batteries
1997 Bounder 36S
I can explain it to you.
1997 F53 Bounder 36s
13 REPLIES 13
Sjm9911
Does your camper have a radio/ audio system? My cd/radio wires are behind my microwave. The radio is under the cabinet next to my stove. So they feed out the side.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
bobsallyh
What type of range hood do you have? If 12 vdc light and fan, do they work or never hooked up?
dougrainer
Since the wires are OEM. It may be for a small 500 watt Inverter to power the entertainment system. Those were popular back in the mid to late 1990's. Fleetwood used to have the Power center(Power Converter/12 volt fuse block above the refer back then. But if the wires go in the roof they come out someplace else. Either the Coach battery compartment or by/behind the 12 volt coach fuse center or behind the 120 breakers. Doug
enblethen
Look around the battery compartment for other end.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MrWizard
Moderator
Moderator
The wires go to right and into ceiling with the other wires, there is no voltage,, the DC fuse panel is only 3 ft away directly above the fridge, im dure these are spare 12ga red&black 12vdc type wiring, , i just wonder what for, extra light, another fan, range vent works, ceiling vent works,, all the lights work, its my inate curiosity that is piqued
enblethen
Maybe not a true 12-volt microwave but run 120-volt microwave via an inverter.
Bud
USAF Retired
Pace Arrow
profdant139
Some of those wires look like 10 gauge?? If so, maybe this was for an inverter, using heavy wire to minimize voltage drop.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
monkey44
Nomad II
Nomad II
Could be direct wired from a generator compartment, if you have one.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
dougrainer
enblethen wrote:
Prewired for 12-volt microwave?
Never been a 12 volt Microwave for RV's. Doug
valhalla360
Navigator
Navigator
"Real men" always have extra parts because they are that good.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
QCMan
Nomad III
Nomad III
Is there any voltage to them? Also, the rest of the wires seem to be overhead and those wires head off to the left. They look a bit too big for unused external speaker wires so that is out. What is off to the left as they seem to go in between the lower cabinet trim panel and the floor of the cabinet but you probably noticed that already. Keep us posted as that is a good mystery!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
wa8yxm
Many RV's are made with "Standard" wiring harness.. They use the wires they need. And leave the rest "N/C" (not connected)
enblethen
Bud
USAF Retired
Pace Arrow
