Splendide Washer/Dryer
revump
We have the Splendide 2000 and lately it has been taking forever to dry small loads. I checked the manual and cleaned the pump pre-chamber, but it didn't seem to help. Any ideas?
Bob
11 REPLIES 11
RAINEYTXX
Lint collects at ribbed section of exhaust hose about 4" froim drum...check there
2012 DRV Mobile Suites Atlanta 43'
2012 F-450
2016 Audi Q5
2011 Audi A8L
2004 Audi A4 6 speed sport package
vance
I'm also thinking that lint has stopped your air flow. I pulled my unit out, opened up the back to access the air flow hose on the back and found it almost completely stopped up with lint. The hose that I refer to has a large opening 3/4 inches where it is clamped onto the back of the unit. At this opening is where I found my blockage.
vance
2007 Coachman Encore
330 HP Mercedes
Honda CRV toad
"If you see our children, PLEASE don't tell them where we are"
MaverickBBD
If you can access the back of you unit, check the exhaust hose. On most install they uncrate the unit. Hook one end to the back and the other to the vent without any concern of proper length. Mine had exactly the same symptoms. Pull the hose and there was a grapefruit size wad of wet lint. Then take a flash light and shine it in the back of the unit as someone looks and rotates the drum to make certain light is visible each time the hole pass the exhaust.
Tom, Cheryl & Blossom(coonhound mix)
'05 Winnebago Journey 36G w/Cat. C-7 350 hp Freightliner XC
AFE air filter, aero turbine muffler, 4 FSD Konis, ultra track bell crank and Safe-T-Plus
FMCA 397030
WIT 129107
Bill_Satellite
Dup.
Can't we all just get along?
Bill_Satellite
There is a filter in the top back corner of the unit that traps lint and if it gets clogged you will not have enough air flow for the dry cycle. I removed this filter as I don't care if lint gets blown outside. I have a straight exhaust with an outside cover that just sends the air downward. Even so, this can get clogged on rare occasions. I am able to unscrew this cover and remove the lint and assemble again. Takes about 2 minutes.
John_Joey
revump wrote:
The only exhaust vent I have goes to goes out through a louvered vent outside. Do I remove it to get to the exhaust hose?
Feel the door on the dryer, if it is warm then more then likely your exhaust is plugged. My Splendide uses cold water to dry, so I can't help on yours, but I'm guessing you'll have to pull the unit and disconnect the hose at the unit to see what you have to work with.
As someone else said call the company, they will have the correct answer for you.
Thereโ€™s no fool, like an old fool.
Valkyriebush
Call Splendide, They have tech reps that will tell you exactly what to do! They are very helpful. If you need a part you can kill two birds with one stone.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
Scottiemom
My Splendide quit drying. . . it still worked and tumbled but no heat. Required a new board which was an expensive fix, but that was a couple years ago and it's still working fine.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
dons2346
My Splendide as a filter on the back of the unit. It does get dirty so it it cleaned. Just look at your setup and see where things might get clogged up. Sometimes you have to take things into your own hands to solve a problem.
revump
Bob
Executive45
When's the last time you cleaned the exhaust vent?...get a long cleanout brush from WalMart..less than $10..pull out all the old lint and junk out of the exhaust vent.....Dennis
Lint Brush
