Sulfur Smell from Water Heater - Please Help!
SnugBugs
So, we are getting our 2006 Winnebago Outlook 326A ready for an extended journey, and are encountering the sulfur smell coming out of the water heater (apparently caused by bacteria proliferating in water left in the heater while it was stored...yay!). We have already done a bleach flush of the heater (dump old water from heater through drain, add dilute of bleach to fresh tank, run hot taps until bleach water fills heater, wait overnight, blow out heater water through heater drain, flush whole system with fresh water), and though it did take the stank down from a 10 to about a 3, it's still there. We have a camphost position starting in 2 weeks and need to have hot water! Can anyone assist us who can offer advice we can count on? We don't have time to experiment, unfortunately, we just need it fixed.
Water heater is an Atwood.
Thank you, O great ones, please share your wisdom with us newbies so we may not stink of old eggs...
21 REPLIES 21
darbyjudy
I had the same problem when I had a new water heater in the home replaced. They had to remove the anode rod. After it was removed the smell was no more. So that is one thing to check.
2004 Gulf Stream 36 ft Sun Voyager triple slide
Workhorse W22 8.1
2004 Saturn VUE w/stowmaster towbar
Two Ole Pharts & One Little CocaPoo named Cuddles
Pipeman
I poured bleach into the heater via the drain plug. I poured it in until it started to drain out. Put the anode rod back in, filled it with water, ran it through the system and let it sit for a day or so. I then drained it and flushed the whole system with clean water. When I dewinterize I will do it again to be on the safe side and install a new anode rod. Hopefully that will solve the problem.
Pipeman
Ontario, Canada
Full Member
35 year Fire Fighter(retired)
VE3PJF
dave17352
I agree with just flush flush flush. Some water smells like sulfur right out of the faucet. I my own house we get it now and then, we are on a rural water system.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Dusty_R
Look for an aniod rod in the water heater, and remove it.
Dusty
Shadow_Catcher
I would not use vinegar in the system after bleach which will release chlorine gas without a great deal of care. Flush again and use bicarbonate of sodium.
SCVJeff
Sounds like my dad's old Winnebago Chieftain in San Diego County. He rarely took it out, and sulphur content in the water in Fallbrook is terrible. All we could really do is flush, flush, flush. Sooner or later it'll go away, and if you're going on the road the problem may not last long.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
Old-Biscuit
IF the bleach treatment didn't get rid of the sulfur smell then you will need to do a vinegar soak.
FLUSHING YOUR WATER HEATER TO REMOVE
THE ROTTEN EGG ODOR
1. Turn off your main water supply. Drain you water heater tank. Reinstall drain plug. Remove the pressure-temperature relief valve. With a funnel use 4 parts white vinegar to two parts water. (In a 6 gallon tank that would be 4 gallons vinegar to 2 gallons water).
2. Cycle the water heater, letting it run under normal operation 4-5 times. At no time do you remove the vinegar from the tank or open any faucets.
This will take time cause WH has to cool down then refire repeat for 4-5 times.
3. Once this has been completed, remove the drain plug and drain the
water heater.
4. Flush/rinse water heater thoroughly with a wand thru drain hole stirring up any sediment. Then turn on water supply and force flush out drain hole.
5. Turn off water, install drain plug, then turn water back on and open PRV letting water flush out thru it.
6. Let PRV snap close, open faucets hot side one at a time to flush lines
No more stink of old rotten eggs.
