Tank level indicator isn’t lighting up
pweekly
Hi all. I have a 2005 Mandalay Motorhome and the control that shows the tank and water levels won’t light up when I push the switch. On that same panel is the water pump and that switch works and lights up. Any ideas what it could be? Bad switch? The fuses in the back all seem ok.
Thanks.
Trish
Tricia and Tom
:B
2005 Mandalay 40E 400HP cummins/Freightliner in Sapphire blue.
4 REPLIES 4
mchero
Good news! Good job!
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
pweekly
Thank you both. Turns out it was simple. Bad Fuse. Fuse looked fine too. Bought a set of new ones and am now good to go. For once, it was a simple thing.
Tricia and Tom
:B
DrewE
I agree, the fuse would be the first thing to check.
A bad switch is certainly a possibility. Sometimes you can tell by feel if a switch is wearing out, sometimes not so much. A loose or broken wire or solder joint in the monitor panel circuitry could likewise be another possible cause.
ScottG
Probably a fuse. Most of the time you cannot tell if a fuse is OK by looking at it unless you take it out and look very closely. Even then it can be hard.
