Oct-07-2013 02:21 PM
Oct-09-2013 03:00 PM
ktmrfs wrote:MEXICOWANDERER wrote:
The only inductive voltage "measurement" devices I have ever seen were detectors warning of the presence of an electromagnetic field. Either the field met pre-set threshold value or it didn't. High Voltage to me means the magic 14 foot corona limit on standard networks. Hotstick and "High-Voltage" is an oxymoron. Especially for the guy on the end of the stick 😉
there are a few around, mostly using optical sensing devices that just happen to be sensitive to an electric field. However they were designed specifcally for measuring high voltage transmission lines with lots of constraints on how they could be used. But again extremely specialized and don't think there was any big use of them.
I spent several years off and on working with optical sensing circuits for electric fields seeing if there was a way to use them to get any repeatable quantitative voltage measurements on traces on a circuit board without making electrical contact. to many issues about surrounding fields to ever get anything remotely useable.
All it yielded was a slew of patents for other optical applications that fell out of the work.
Maybe someday in the future a smarter mind and new technology will prevail.
Oct-09-2013 02:00 PM
...Unless a person can screw up a bowling ball with a feather duster...
Oct-08-2013 07:47 PM
Oct-08-2013 07:23 PM
Oct-08-2013 12:59 PM
Oct-08-2013 12:52 PM
Oct-08-2013 11:55 AM
Oct-08-2013 11:53 AM
MEXICOWANDERER wrote:RandACampin wrote:
They are good leads but not the best. They do have strength, and are a high quality lead. There is at least on flaw in them, and yes I do use them. The large finger guard on the end makes it impossible to get into tight spaces. They are a good lead though.
Here ya go hoss. Oldaker is a USA company so they understand issues with test lead function...
Oct-08-2013 11:47 AM
Argosy24 wrote:
A clamp meter will check voltage and current in a wire WITHOUT leads, simply put it around the wire.
Oct-08-2013 11:08 AM
Oct-08-2013 11:05 AM
Oct-08-2013 11:02 AM
Oct-08-2013 06:47 AM
Oct-08-2013 05:39 AM
Argosy24 wrote:MEXICOWANDERER wrote:
Pierce wire insulation? "Shirley You Jest".
Piercing the insulation is one of the worst things you can do when testing. Eventually it will bite you and be all but impossible to find and a difficult repair.
Vehicles manufacturers have gone to great lengths over the years to seal the entire electrical system because of corrosion problems. Even a tiny hole will be the weak point in the insulation for eventual failure.
Clamp meters will check for voltage and current, AC and DC, in wiring without damage. If you do your own repairs they've gotten cheap enough one should be part of your tools.
