โMay-27-2010 02:06 AM
โApr-29-2011 06:45 AM
โApr-29-2011 05:32 AM
โApr-29-2011 03:53 AM
MrRchitty wrote:
The relays for my unit are inside the air intake. The low and high each had the letters L and H labeled next to each of their respective terminals. I simply pulled the wire with the L label and the blower, which was on low, stopped. That is when I tried to get the little Champ to start just the compressor without success.
โApr-28-2011 07:26 PM
PrivatePilot wrote:
Back on the topic, It's looking like I'm going to have some spare time this coming weekend, so I'm going to be installing a hard start cap on my AC. I'm also going to wire in a remote toggle to the fan motor so that I can isolate it's load and provide 100% of my 2000i's power to the compressor. If there's any way in heck this generator will fire off an A/C, this will be it.
I'll report back if I have success or not.
โApr-28-2011 07:17 PM
โApr-28-2011 06:54 PM
Hybridhunter wrote:MrRchitty wrote:Hybridhunter wrote:
I also tried starting my Dometic Brisk Air 13.5KBTU, not a chance. I will try again with a hard start capcitor.
It will not start your AC unit. It has been tried a few times on this forum. I tried a while back with the blower relay pulled so as to only have the compressor start alone. Under the white cover on the roof will be the specs for just the compressor, mine requires (from memory) 4200 watts to start it. It's not going to work. You will need the 2 in parallel.
Besides, I just pulled my hard start out last weekend. It failed. It was causing the breaker to pop after about two minutes. With a clamp meter it measured 30 amps. 10 amps after pulling it.
Again, the little Champ is not going to start the 13500 AC unit. The professor has kindly pointed out pages in the manual of the ratings.
Please, keep us updated on the converter issue. Good luck.
If you were somehow drawing 30 amps to your AC with the cap on it, it was connected wrong, or it was the wrong cap. Or the cap was screwed up, so saying it won't do it after that type of scenario is inconclusive. Which cap did you use, and who else had tried to start their AC with the 2000i? I've looked for posts, and can't find any.
I know with the Honda 2000, at my elevation, (around 1000'ASL) it will start a properly set up Brisk Air 13.5K
โApr-28-2011 06:53 PM
โApr-28-2011 06:38 PM
PrivatePilot wrote:Hybridhunter wrote:
Champion informs me they have updated programming for the control module to better handle surges.
More info, please!
I'm assuming this is a physical hardware swap that is required...are they providing you with parts, or what's the deal here?
โApr-28-2011 06:30 PM
โApr-28-2011 02:46 PM
โApr-28-2011 02:39 PM
โApr-28-2011 01:50 PM
โApr-28-2011 09:48 AM
โApr-28-2011 01:44 AM
โApr-27-2011 08:31 PM
