Thermostat not getting 12v
KotzurJ
Hey guys, first post just recently started full timing in a 2004 KZ inc. New Vision 34โ€™ 5th wheel. Everything worked great until last week, the a/c started short cycling and the LP leak detector started screaming and showing a fault. I replaced the thermostat which changed nothing big surprise. I canโ€™t seem to figure this out. I test for voltage at the thermostat and Iโ€™m getting 1.67v so Iโ€™m figuring loose connection somewhere. I bypassed the leak detector thinking that was causing an issue but it didnโ€™t solve anything. Breakers are alll fine, fuses are good, we are connected to shore power. No other power issues only the thermostat. Iโ€™m searched but couldnโ€™t find anything already posted. If anyone has any ideas please let me know. I have a Coleman Mach cool/heat slider thermostat, a airxcel rooftop ac, and I donโ€™t know what brand of furnace, itโ€™s right beneath the stove if that helps. Coming into winter just trying to get this furnace burning.
28 REPLIES 28
wnjj
Sounds like you have a poor 12V connection from the fuse box to the furnace.
When you ran the jumper wire to test the thermostat and A/C, did you also connect the 12V wire from the furnace up there at the thermostat to the jumper? If there is a poor supply wire to the furnace that would send power from the jumper back down to the furnace to override the original connection. If that works you need to find the bad connection from the fuse box to the furnace.
Did you try running a jumper wire from the fusebox to the furnace instead of using the one that pulls down to 1.5V?
For the wire nuts you tightened, did you remove them and inspect the wires? They should never need tightened and I suspect the wires may be damaged. Make sure all of the strands are intact, particularly where the enter the insulation. If you pull the wire nuts you may need to cut the ends and strip them back a bit further to ensure a good connection. The wire nuts do not make the connection. Twisting the wires together is supposed to do that and the wire nuts only hold the twist in place.
KotzurJ
Hey guys, So I still haven't figured it out. I tightened some wire nuts and got the 12v supply to give 12v. However whenever I go to test at the wire nut junction on the furnace RED, T-RED, +BLUE and 12v+ wire nut it is reading 1.5v until i remove the 12v+ wire then it reads 13.6v on the 12v+ wire. So there is an immediate voltage drop whenever I join all of the wires together. I tried jumping the 2 blue wires together but the furnace does not kick on. I also tried putting a jumper wire from my fuse box to supply 12v (or more accurately 13.7) to my thermostat. Whenever I did that My ac kicked on when set to cool, but my Furnace would not kick on. So to me that shows that the Thermostat and rooftop AC unit are both functioning. Which leads me to be believe that there is a wiring issue or connection issue or something in the furnace since the 12v is starting there and moving from the furnace to the thermostat and the ac. I am sort of at my wits end.
LouLawrence
Have you checked your meter on some other 12V source to make sure it's reading 12V accurately? Bad battery in meter or wrong setting on dial can screw you up.
opnspaces
Navigator II
Navigator II
So you are going from 13.7v at the fuse box to 2.5v on an orange/white wire in a drawer to 1.67v at the furnace? that's some serious voltage drop.
If you pull the furnace fuse what else goes dead in the trailer?
When you test 13.7v are you getting that 13.7v on both sides of the fuse? I'm assuming you are testing in the little windows on the back of the fuse while it's plugged into the panel?
can you get behind the fuse panel? On my trailer I can remove a drawer just above the panel and access the wires right behind. If you can get behind the panel is the orange/white wire back there?
KotzurJ
I traced the power source for furnace to a wire nut union beneath the a drawer that is orange and white and coming out of the wall. It reads 2.5v, I cannot seem to find a orange and white set of wires on the fuse box anywhere so i am not sure where these wires are coming from.
KotzurJ
I Tested all of the Fuses, they all read 13.7v. I will do the test with the wires next.
opnspaces
Navigator II
Navigator II
Did you do any additions to the trailer that involved screwing or nailing into anything? If so you probably hit a wire.
First thing I would do in your situation is identify and make note of your power. Since no battery start at the fuse box. The furnace is 12v so ignore the breakers and concentrate on the fuses. Take a reading from positive to ground at the fuse box and write it down and let us know what it is. Is it 12.7, is it 13.6, is it 12.1, is it 11.2 what is the voltage it does make a difference.
After that I would take that wire nut off the red wires and separate the wires.
The small red wire is obviously the thermostat.
The blue wire is the furnace.
I'm assuming the large red wire goes to the blower.
So that leaves the white wire as your suspected 12v positive.
Make a temporary connection to test. Under the wire nut add
the small red wire
the blue wire
the wire that goes to the blower (assuming the red one but if it's the white then use the white)
Your jumper wire back to known good power
Leave out the wire that is reading 1.8v, just tape it off.
Now does the system work?
CA_Traveler
With only 1.8V from the 12V supply you need find out why. The options are bad connection, cut wire or bad fuse including fuse contacts.
Again a wire tracer can be very helpful. Buy, beg, borrow or steal one. OK maybe not the last option.:B
2014 Grand Cherokee Overland
Bob
KotzurJ
Tried running the jumper still getting 1.8v from the red wire on furnace and a good ground. All of the fuses Iโ€™m seeing are good. Iโ€™ll try jumping the two blue wires and see if it starts.
dougrainer
bottom furnace picture.
The RED(large gauge) and RED small gauge are connected to the 12 volt positive supply as well as ONE of the BLUE. THAT connection supplies 12 volt positive to the FURNACE and also supplies 12 volts to the wall Tstat. IF NO 12 VOLTS AT ALL, THEN YOUR 12 VOLT SUPPLY FROM THE FUSE CENTER IS THE PROBLEM. Take a voltage reading of ALL the fuses at the fuse holder. ALL should have 12 volts on both sides of fuse. Doug
opnspaces
Navigator II
Navigator II
Here's the pictures. It appears imgur doesn't allow public linking so I copied your pictures over to the rv.net photo posting site Link
Click For Full-Size Image.
wnjj
CA Traveler wrote:
IF these are 12V power wires then what is the voltage of each one from a good frame ground? A wire tracer can be very helpful in tracing wires.
Good suggestion.
Use a length of scrap wire to connect to a known good ground like at the fusebox. Then measure with that ground versus the red wire at the furnace. Repeat the process with a known good 12V source versus the black wire to make sure the ground is good. As it is now, either wire could have a poor connection.
wnjj
KotzurJ wrote:
For some reason the images are only opening on my posts if you open them in a new tab. Atleast from my end, I'm not sure if they are showing up for you guys.
Pictures don't show for me but if I use the link they work fine. It could be my browser.
https://imgur.com/a/ZMrkahw
dougrainer
There are 4 wires at furnace. The RED should have 12 volts. THAT then feeds 12 volts to one of the Blue wires. Check that red wire and report back. IF the red has 12 volts, jumping the 2 Blue together will start the furnace. Disconnect the Blue's to stop the furnace. You had tested previously. The BLACK going to the RED should have 12 volts. CHECK the 12 volt fuses in the Breaker box where the 120 breakers and the ATC fuses are. 1.8(lower than 12 volts) volts is sometimes the result of a LOOSE 12 volt ATC fuse in the fuse block. Do your ceiling lights operate with normal brightness? Doug
