โApr-26-2017 07:16 AM
โApr-30-2017 09:44 PM
โApr-30-2017 09:34 AM
enblethen wrote:Try what Bud suggested first, I use an allen key. If that does not work you my have mineral buildup from hard water over the years. I had to remove mine and scrape the build up off of the blade seal. The build up would have prevented even a new seal from working.
What model Thetford toilet?
many have a groove that the slide goes into. Any small piece of debris will cause the slide not to close fully.
Thetford makes an angle cleaner. It has about a one inch arm bent 90 degrees to the shaft for cleaning grove. I made my own out of a metal coat hanger. Bent one end 90 degrees. Left hanger about eight inches and bent other end into a handle.
โApr-27-2017 03:04 PM
โApr-26-2017 11:00 AM
โApr-26-2017 08:15 AM
โApr-26-2017 07:54 AM
Bud
USAF Retired
Pace Arrow
