Forget about it ...
You will save next to nothing on the electric bill
Your only real savings, would be the extension of dry camping time
A/C MW heat use large amounts of power, to realize any electric bill savings your system would have to be large enough to power those items from a large inverter, being powered by the large solar array
On shore power once batteries are fully charged, then charging becomes a mute point, as parasitic drains and maintenance require very little power, the power for lights and maybe the TV could be off set by solar, but the MW and a/c , electric heat etc.. Would still be on the meter, Not inverter powered by solar, unless you get a full-time off grid system, a modest system is not going to power the MW or a/c, and even if you bought a large 3000w inverter, you would need a large battery bank
So yes you can get some minor reduction in the electric bill, by using solar charging the batteries and using an inverter for low power items
But the couple of dollars a month might not justify the expense of the install
Solar on an RV, in a FHU campground, is not grid tie feedback
Supply power to grid during the daytime peak and then use power st night at the lower rate, you can't do that in a campground, it's not like a house
Unless you set it up that way on your own property
We have solar, we full time, mostly off grid
And we use the generator almost everyday, MW a/c , are on the generator , solar battery power handles the fridge tv pc lights etc..
Big power items are almost exclusively generator
I can run the coffee maker or the MW or the vacuum from the inverter, but I pay for it with extra generator powered recharge time into our bank of (8) batteries
We mainly have the solar and the batteries, because we have a residential fridge and I am a power hog using the pc many hours a day
The best way to save on the electric bill, is too run everything you can in the TV from propane, fridge, water heater, heat using outro propane
I can explain it to you.
1997 F53 Bounder 36s
