voltage drop
tlaffourtit
how much voltage drop is normal for a agm 12v battery or any battery if it is fully charged and connected to nothing?
Sue and Tim
38 REPLIES 38
tlaffourtit
thanks smkettner for the info. I copied a page from my inverter/charger manual about charging. will this type of charger charge my batteries correctly and not shorten their life?
There are 3 charging stages:
Bulk Charging: This is the initial stage of charging. While Bulk Charging, the charger supplies the battery with controlled constant current. The charger will remain in Bulk charge until the Absorption charge voltage (determined by the Battery Type selection) is achieved.
A software timer will measure the time from A/C start until the battery charger reaches 0.3V below the boost voltage, then take this time asT0 and T0ร—10 = T1.
Absorb Charging: This is the second charging stage and begins after the absorb voltage has been reached. Absorb Charging provides the batteries with a constant voltage and reduces the DC charging current in order to maintain the absorb voltage setting.
In this period, the inverter will start a T1 timer; the charger will keep the boost voltage in Boost CV mode until the T1 timer has run out. Then drop the voltage down to the float voltage. The timer has a minimum time of 1 hour and a maximum time of 12 hours.
Float Charging: The third charging stage occurs at the end of the Absorb Charging time. While Float charging, the charge voltage is reduced to the float charge voltage (determined by the Battery Type selection*). In this stage, the batteries are kept fully charged and ready if needed by the inverter.
If the A/C is reconnected or the battery voltage drops below 12Vdc/24Vdc, the charger will restart the above cycle.
If the charge maintains the float state for 10 days, the charger will deliberately reset the cycle to protect the battery.
Sue and Tim
time2roll
Gau_8
As mentioned, the higher voltage reading from a freshly charged battery that has had no drain applied is know as "Surface Charge." It will quickly drop to the 12.6v range once a load is applied.
Gau_8
pianotuna wrote:
Hi,
Do you mean agm battery?
Self discharge can be as little as 1% per month or as great as 1% per day. It depends on the chemistry that the battery maker is using.
How does the chemistry vary? They are all lead/acid batteries.
tenbear
This higher voltage that leaks off when the charger is disconnected is a phenomenon called surface charge. It is perfectly normal.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
pianotuna
Nomad III
Nomad III
Hi,
As Land pointed out AGM batteries initially need to be used. I'd do about 5 cycles to 50% followed by rapid (compared to flooded) recharges. The less you pay for the agm the more likely this is going to be needed.
I'm lusting after a pair of 8D agms, since LI is not going to be affordable in the near future.
I wonder if I got twin 8Ds, and four Group 31's from the same company if I'd keep my charging profiles the same for all batteries.
Regards, Don
tlaffourtit
landyacht318 wrote:
AGM fully charged resting Open Circuit Voltage varies widely. My Northstar AGM is 13.06v
12.7v rested OCV would be about 70% charged on my battery.
Your voltages seem fine for Deka/East penn AGM, but I would try and see if you can get a fully charged rested voltage from them, and post their answer.
FWIW, when I first got my AGM, I could not get the rested voltage above 12.7v until I did a ~ 50% discharge and a 25 amp+ recharge, and the battery has been doing tarzan yells and thumping its chest like a meth addled gorilla since.
message sent. will post reply when sent.
Sue and Tim
tlaffourtit
Crazy Ray wrote:
Google 12volt side of life. great read
good read there. thanks
Sue and Tim
landyacht318
old_guy
it also depends on the condition of the top of the battery. if it has dirt on it, it will discharge at a faster rate. my friend owns a battery store and he showed me the difference one day on a clean top and a dirty top.
Mandalay_Parr
12.7 is full charge.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Crazy_Ray
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
tlaffourtit
found this online. mostly the same info from before.
SPECIFICATIONS
Nominal Voltage: 12-Volt/145 ampere-hours
@ 8 hr. rate to 1.75 final v.p.c.
Positive Plate: Pure lead, low-calcium, high-tin alloy
Negative Plate: Lead calcium alloy
Post Seal: Epoxy-sealed
Terminal: Front access, 1/4" - 20 threaded insert
Container: Flame-retardant, polypropylene -
UL 94 V-0/>28% L.O.I.
Safety Vent: Low positive pressure, self-sealing
w/ flame arrestor
Float Voltage: 2.25 v.p.c. ยฑ 0.01 v.p.c.@ 77ยบF (25ยบC)
(Range: 13.44 to 13.56 volts per 6-cell battery)
Battery Life: 10 years in float
applications at 77ยฐF (25ยฐC)
Dimensions: 17.58" (446.6 mm) L
x 6.89" (174.9 mm) W
x 10.10" (256.5 mm) H
Weight: 105 lbs. (47.7 kg)
http://www.eastpennmanufacturing.com/wp-content/uploads/0737-Unigy-I-Ohmic-Values.pdf
Sue and Tim
Dakota98
tlaffourtit wrote:
the batteries I have i float at 13.5v. once I disconnect them from the charger; I am guessing they shouldn't stay at 13.5v but drop down into the 12v range? example I had the batteries floating at 13.5 volts for a couple of hours. then I disconnected the charger and took a reading of 12.96v across the 8 battery string. this morning the reading was 12.84v. my question is; it this normal? you responded it depends on the make up of the battery. is there any other information I could get from the battery label to help?
I would say that is quite normal. If you were reading the voltage at 13.5 volts while the charger was still plugged in & connected to the battery bank, that reading was from the charger, not the batteries. A 12.6 + volt reading taken directly from the string or individual battery indicates a fully charged battery. Unfortunately you can't check them with a temperature compensating hydrometer, since they are sealed AGM's
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
tlaffourtit
pianotuna wrote:
Hi tlaffourtit,
What make and size of batteries?
deka is the brand name
part No.: 12avr145ET
nominal voltage: 12v
capacity 145 ah @ 8 hr rate to 1.75 vpc
float rate: 13.50 +/- .06 vpb @ 25*c
weight: 105 lbs, 47.7 kg
torque value: 100 in. lbs, 11.3 Nm
non-spillable
Sue and Tim
