Washing your hands
RLS7201
I've been swinging a wrench professionally since high school. IE: auto mechanic, Operating Engineer, job shop machinist, Director of Maintenance of an ink production facility, etc. I just finished up rebuilding a differential in an off road pick-up, for a client.
Always looking for a better way of cleaning my hands and nails.
There is some pretty good stuff out there to clean up with, but it takes up space on our RVs.
Out of necessity, I had to use DAWN Direct Foam to wash my hands and nails, while on the road. WA-LAH! It works as well if not better than some of the products designed for mechanics.
So that leaves one less bottle or jug of stuff to carry in the MH.
The wife will have to share her dish washing soap with me. Give it a try.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
25 REPLIES 25
pennysmom09
Another fan of Dawn, for hands, dishes and anything else. The foaming Dawn is too watery for me so I stopped buying it. Extra money for diluted Dawn!
Nancy and Doug
2015 KZ Durango 325RL FW
Campfire_Time
Many years ago I had to change a fuel pump on my Suburban while in a CG. This was back when fuel pumps were still mechanical and were attached to the outside of the engine block. Very greasy dirty job even though it was relatively easy. I did not carry hand cleaner back then. We did have some powdered Tide clothes soap. It worked fantastic.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
Bipeflier
I use nitrile gloves for jobs that don't require much "feel" but if I have to go bare handed, an old trick is to use some Dawn as a hand lotion before starting to work. Rub it in real good and wipe off any excess, then go to work. When you are finished the soap is in all your pores and the gunk comes right off with hot water and more Dawn.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
KCFDCapt
time2roll wrote:
Lately I find prevention by wearing latex gloves to be the way to go on a messy job.
Latex breaks down quickly with petroleum products. Nitrile is a far better choice for gloves.
folivier
Dawn foam does work great but will pull all the natural oils out of your skin. So after using it I have to use skin lotion.
FYI my wife makes foaming soap by reusing the foam pump bottles with water and a little bit of liquid soap of any kind. Try it and you'll realize how little soap there is in those ready made bottles. Add a drop of food color and a drop of whatever scent you like if you prefer.
wa8yxm
My hands are NEVER cleaner than when I finish washing the dishes.
JIMNLIN
I've used Simple Green since it became available. I keep a squirt bottle in the tractor shed and garage and under the bath room sink.
Tractors/mowers/balers equipment get very dirty grease and can stain the hands and clothes. Squirt it on my hands/arms and simply wipe off.
Then hand soap and water when I get up to the house.
All_I_could_aff
In my younger days...
1) Hand lotion before getting greasy,
2) Then clean up with a dribble of Automatic trans fluid to loosen the grease
3) Followed by powdered hand soap with fine pumice.
4) squirt of dawn dish detergent.
5) 12 ounces of cold beer
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
Lynnmor
I've used Boraxo Powdered Hand Soap for at least 40 years. I find that the abrasive granules do more good than a slimy liquid soap.
Ivylog
Dawn Foam is in my shower...it and Tide for my work clothes is all I use.
Upgraded with a 08 HR Navigator 45โ€™...
SidecarFlip
Dawn is good for cleaning out your cooling system as well, cuts the crud in an older radiator just like the crud on your hands.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
azrving
Similar background and my best solution is to have stopped doing most of that stuff. I still have to do some stuff of my own but what a relief looking down at my white finger nails right now. ๐Ÿ™‚
gbopp
I've been using Dawn for a long time. It's cheap and readily available.
If it's good enough for ducks, it's good enough for me. ๐Ÿ™‚
K_Charles
Old-Biscuit wrote:
I used 'oil' to clean gunk/grime off hands, wipe excess off with shop rag and then regular hot water and soap when I was a working soul.
This always worked pretty good. Some good hand cream before you start makes cleanup much easier.
