Water heater help
xaugievike
Hey guys.
On a recent trip the electric side of our water heater conked out on us. I assumed the element gave up, so I ordered and installed a new one. To no avail.
So I dug deeper. This ismamsuburban sw6de
1 - yes, I checked the breaker.
2 - no voltage at the electric element
3 - I did have voltage at the line to the water heater as checked at one of keystone push connectors near the WH.
4 - I checked the switch for continuity and it checked out...
Only thing I'm not sure on is the thermal overload buttons. I pushed them - pretty firmly - and had no indication that one was popped or reset.
12v (gas) works perfectly
Your thoughts? I admit I'm a couple credits shy of my electricians license...but I think I checked everything correctly.
2015 Chevy Silverado 3500hd DRW.
Pulling Keystone Cougar 325SRX
A buddy and I started a blog - you can read it here:
http://twoguyscamping.blogspot.com
8 REPLIES 8
xaugievike
That was it guys. All is up and running. Thanks to those that chimed in with help!
xaugievike
Looks like it's my culprit. Bottom connection for the wire is clearly burnt out. Zero continuity. New piece inbound. Thanks guys.
bob213
Thanks Old-Biscuit. Can always depend on you!
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
Old-Biscuit
bob213 wrote:
Would some one please refresh my memory..Thermostat position....
Gas left--electric right?
Opposite
120V AC Left........BLACK wires
OEM Standard 130*F is 232306
Optional 140*F is 232317
12V DC Right........RED wires
OEM Standard 130*F is 232282
Optional 140*F is 232319
IF wire to t-stat has rubbed against edge of cut-out for t-stat or if connected wire from Top (HI) to bottom (normal) is burnt into no 120V can get to element
IF HI t-stat has tripped you can push to reset it when water temp has dropped below 110*F
This one shows burnt connector wire on 120VA AC set
bob213
newman_fulltime
232306 .is what you need
xaugievike
Donn - thanks for the reply. Is this the piece you are referring to?
Clicky
donn0128
25 bucks at a real RV dealer will get you a new temp pack. Four screws to remove the cover, one screw to R&R the pack. No need to drain the water tank. Take the cover off and check for voltage across the thermal pack.
