Water heater
globehopper
Arrived at the campground hooked everything up but electric heater didn't work. I hooked up to city water waited until water flowed freely and then turned on switch always worked until now! Gas water heater runs fine. Any ideas?
7 REPLIES 7
Dick_B
After 10 years of use my WH wires fried and I have to completely dismantle it to fix it. But start with something simple like the switches mentioned before taking it apart.
It is like mine the wiring is almost impossible to get to.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
j-d
Unplug and re-seat the "edge connector" to the heater's circuit board. My first thought is that a connector problem would keep it from working on LPG as well as 120VAC. But it's a free try.
1fastdad
Most of the time the problems are bad connections at the water heater. Just try removing and reinstalling all the connections.
CJW8
I tried for an hour once to get mine working after de-winterizing. Then I realized I still had the bypass valve in bypass.
2003 Forest River Sierra M-37SP Toy Hauler- Traded in
2015 Keystone Raptor 332TS 5th wheel toy Hauler (sold)
2004 Winnebago Vectra. 2011 Jeep Grand Cherokee toad
TucsonJim
I know on my Suburban,there was also a switch in the water heater compartment that was very difficult to see. When I was cleaning the compartment one time, I accidently switched it off.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Old-Biscuit
AC breaker tripped
Bad t-stat/tripped t-stat
Bad element
Suburban has separate t-stats and are resettable (In outside compartment under cover that states 'Push to Reset') Left one is for 110V AC element.....right one for 12V DC propane)
Atwood uses same t-stats for both so if propane is working it isn't a t-stat problem
Really depends on which Brand/Model water heater.
Helps us out with more info :B
1492
Moderator
Moderator
Moved from Forum Technical Support
