Aug-22-2022 04:45 PM
Aug-25-2022 04:56 PM
Aug-25-2022 05:35 AM
Aug-25-2022 02:28 AM
Aug-24-2022 05:29 AM
Aug-23-2022 01:06 PM
Aug-23-2022 11:23 AM
Aug-23-2022 08:24 AM
Aug-23-2022 07:54 AM
nickthehunter wrote:
All the ones I have seen - the cap shouldn’t make any difference, there should be a valve, is the valve fully in the correct position, which is the only thing that matters.
Aug-23-2022 05:33 AM
shadows4 wrote:All the ones I have seen - the cap shouldn’t make any difference, there should be a valve, is the valve fully in the correct position, which is the only thing that matters.
wa8yxm I had thought of that and checked if the cap was tight. Is there supposed to be a gasket in that cap? Thanks
midnightsadie I had thought of that too but the pump works as it is supposed to when I attach a hose and stick it in a bucket. When I do that the strainer is still attached.
What really puzzles me is there is no water dripping anywhere I can find. I would think if it was sucking air it would leak also.
Aug-22-2022 05:40 PM
Aug-22-2022 05:37 PM
Aug-22-2022 05:26 PM
Aug-22-2022 05:20 PM
Aug-22-2022 05:04 PM
