โOct-02-2013 05:58 AM
โOct-04-2013 01:07 PM
โOct-04-2013 09:33 AM
ScottnSherrie wrote:
Permanent solution is to install SeeLeveL gauges. They are pricey but are excellent. The sensors go on the outside and use an AM radio signal loop to sense the level. They read in smaller increments as well. I had to shorten the sensors and I still get readings in 5% increments.
Just Google for SeeLeveL and check it out. And no, I don't work for them or own stoc, I'm just a happy customer.
โOct-04-2013 09:06 AM
DryCamper11 wrote:Clay L wrote:
sanitizing with 1/4 cup of water per each 15 gallons of water should help.
I think you meant "1/4 cup of bleach per each 15 gallons of water" :).
โOct-03-2013 04:47 PM
โOct-03-2013 08:42 AM
โOct-03-2013 08:30 AM
โOct-02-2013 11:57 PM
โOct-02-2013 11:56 PM
โOct-02-2013 08:54 PM
grouchrc wrote:
For 13 years the sensors on my water tank gage have worked properly. Recently they locked up on 2/3ds full as the water ran out to the point I thought my water pump had failed.
Is there anything i can put in the tank to clean the sensors that won't contaminate the water supply?
โOct-02-2013 01:44 PM
โOct-02-2013 01:32 PM
โOct-02-2013 11:39 AM
โOct-02-2013 10:59 AM
โOct-02-2013 10:54 AM
