Wet and dry bulb comfort measurements
MEXICOWANDERER
https://en.m.wikipedia.org/wiki/Wet-bulb_temperature
Wet bulb, dry bulb comfort measurement.
Wrap the wet bulb thermometer with cheesecloth.
Blow a fan across the bulb.
This is the lowest temperature that evaporative cooling can achieve at that point in time. A very useful tool.
https://www.ebay.com/itm/Economy-Sling-Psychrometer-Kit-Containing-1-Dry-Bulb-and-1-Wet-Bulb-Thermom...
15 REPLIES 15
C_Schomer
I used a Bacarach sling psychrometer my whole career. The red reading thermometers can't take the heat in a service truck so I switched to Mercury and it always had dead accurate calibrations. The newer AC charging charts go by inside wet bulb for one of the parameters so I checked indoor WB every job.
I went from Denver to Phx. In 03 and I thought I would literally die or have to change careers before I learned how to regulate water, electrolytes and food. I ached and hurt from head to toe when I got home at night! Still, when all the water I could hold and the right electrolytes didn't work, usually about 2 PM, I had to go indoors.
The company finally gave us heart rate/core temp monitors but learning to read my own body was the best. Craig
red31
MEXICOWANDERER wrote:
I read 88, 92, 95, 76, 89...
Am I supposed to see words?
I only see multiples of 10 but read 32C and 18C ๐Ÿ˜›
MEXICOWANDERER
That's not digital :B :W
profdant139
Mex, if it's any consolation, even California has felt like Acapulco for much of August -- high temps, high humidities, and now add in a lot of smoke. I can tell you it's miserable, even without a wet bulb.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
red31
this one hung at buddies hunting cabin, it relied on mother nature's breeze.
dad used this one, he was left handed!
mbopp
I used to work in an airflow lab. We had a battery powered wet-dry bulb psychrometer to measure humidity.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
red31
MEXICOWANDERER
I found through the school of hard knocks that in dangerously high temperatures that a pure ice slurpee made in a blender can ward off really awful effects. I Make sure I have enough salt in my system then grind ice and stick it in a thermos. I have lowered my body temperature 2+ degrees by eating the ice. I start off slowly but consume a pint or so of shlilusy ice. Too much, too soon may be hard on the body. Alcohol, caffeine or sugar seems to kick my butt. I don't drink but watching other people, beer and booze are both bad for health in broiling temperatures.
MEXICOWANDERER
Echo
Chum_lee
If you are properly hydrated, in low humidity, you can think of yourself as as cool, wet bulb guy. In high humidity, . . . your're just another sweaty (maybe stinky) guy.
Chum lee
MEXICOWANDERER
No batteries no transistors no drift no plus minus percentage errors. And twelve dollars.
agesilaus
wa8yxm wrote:
One way. in fact the most accurate way. to measure humidity requires a dual bulb (one wet one dry) thermometer a piece of string and a book.
You start by slinging the thing around for a bit.
Read both thermometers and note the temps
Look the dry temp up in the book then the wet and where the two cross
HUMIDITY.
Just get a sling psychrometer, (Amazon} I used them at work to determine the wet bulb temp. That's what the 'Feels Like' temp comes from. It's done electronically now, my indoor-outdoor thermometer does it with no slinging. This old tech....heh.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
wa8yxm
HUMIDITY.
Lwiddis
Only way I survived summers at Ft. Irwin was to keep my uniform wet. Didnโ€™t know the science...did know the relief.
