What caulk for the Winegard antenna cable?
TurnThePage
I'm repairing my Winegard Sensar antenna. The cable goes straight down through a fitting on the roof that is then covered with a boot. There was some kind of white caulk in there before. It was pretty easy to dig out, which I think was intentional. Anybody know what it is?
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
9 REPLIES 9
LouLawrence
Dicor and silicone are incompatible. They will not stick to each other. Unless you have completely removed any trace of the previous caulk (which was likely Dicor) you want to make sure you are using the right caulk.
Lynnmor
23hotrodr wrote:
I use RTV Silicone. Put some in around the coax and some in the boot to slip down on the coax and protruding riser. The RTV is more solid when cured and helps prevent the cable from pulling off the boot when antenna is rotated. Good luck.
That is what I use as well. A silicone caulk with adhesive qualities helps keep the boot in place.
23hotrodr
2007 Itasca Suncruiser 35L
2000 Jeep Wrangler
TurnThePage
I dug around in the garage and found a couple tubes of Dicor. One self leveling and one not. The one that's NOT self leveling actually lists TV antenna as a recommended use. That's the one I'll be using.
2015 Ram 1500
philh
Isn't there a better product than dicor?
Ranger_Smith
TurnThePage wrote:
So just fill the hole with Dicor Self Leveling Lap Sealant?
Yes sir
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
TurnThePage
2015 Ram 1500
enblethen
Use dicor!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Ranger_Smith
Probably Dicor
Where we are now
Steve and Joy
