Oct-10-2019 06:22 PM
Oct-10-2019 10:44 PM
Oct-10-2019 10:06 PM
Oct-10-2019 10:00 PM
DrewE wrote:
If the valve for the low point drains is in the heated section of the RV, there's nothing in the pipes to freeze and cause problems. I would conjecture that this is the case in your RV, though I obviously can't know for sure.
Oct-10-2019 08:59 PM
Oct-10-2019 08:51 PM
lenr wrote:
I'm speaking of two pipes, one hot water, one cold water, that are tapped into lines running along under the water heater, that protrude down 10" under the bottom of the trailer, and are labeled low point drains. I also have a single line from the bottom of the fresh water tank used to drain it. The fresh drain is crossed link flexible PEX. It should handle some freezing. The low point drains are hard plastic probably not going to handle freezing. And, sticking out 10", I don't believe that they would not freeze down close to zero degrees. My concern is how do I prevent freezing and busting when I'm still camping in weather between zero and 32 degrees. I don't have a problem once the trailer is parked for winter full of antifreeze. Eliminating them eliminates busting from freezing, and I don't see why I need them to fill the system with antifreeze.
Oct-10-2019 08:49 PM
maillemaker wrote:
If you remove the drains, how will you drain your system and get rid of the antifreeze in the system?
Steve
Oct-10-2019 08:44 PM
swphotobug wrote:
If you don't have them how are you going to drain the tank. They will be fine and won't break
Oct-10-2019 08:31 PM
Oct-10-2019 07:51 PM
Oct-10-2019 07:47 PM
Oct-10-2019 07:42 PM
Oct-10-2019 07:32 PM
Oct-10-2019 07:12 PM
Oct-10-2019 07:11 PM
