โOct-22-2015 12:55 PM
โOct-28-2015 10:57 AM
mkirsch wrote:RJCorazza wrote:
When I was building RC airplanes out of Coroplast I used a lighter to "flash" both sides of the material very briefly, then a very small amount of super glue will permanently bond.
The process is sensitive to the correct amount of heat, but once I got the hang of it very quick.
Same here. I generally use a butane torch. In the right light, you can see a slight change in the color of the coroplast as the heat passes over it. You don't want to heat it until it wrinkles, just enough to see that slight color change.
The Loctite brand of cyanoacrylate adhesive from Home Depot works best out of all the "CA's" currently on the market.
โOct-28-2015 12:41 AM
mayo30 wrote:Wind River wrote:
Eternabond tape will stick to Coroplast.
Yep works great,simple and fast no mess no fuss.permanent.
โOct-27-2015 01:18 PM
โOct-27-2015 04:13 AM
โOct-26-2015 11:06 AM
โOct-23-2015 02:22 PM
โOct-23-2015 12:19 PM
โOct-23-2015 08:31 AM
โOct-23-2015 05:48 AM
โOct-23-2015 03:17 AM
โOct-22-2015 07:06 PM
โOct-22-2015 06:10 PM
โOct-22-2015 05:53 PM
โOct-22-2015 05:42 PM
Dave H M wrote:
That is a good idea Mex.
That stuff is nasty to work with but may be the cat's meow.
Ford man, what kind of sealant are you referring to?
