Jun-04-2021 05:35 PM
Jun-06-2021 08:00 AM
BFL13 wrote:Yup, my controller input is about 8A at 90V+.
The 14.8v at 60 amps would be output while input voltage is at Vmp. Over-panelling the input would refer to the 60 amp output limit. Getting lost here somehow.
Jun-06-2021 07:39 AM
Jun-06-2021 07:34 AM
Jun-06-2021 07:15 AM
Jun-05-2021 07:09 PM
CA Traveler wrote:MrWizard wrote:Of course but the post was intended to emphasis the difference between 12V and 48V in terms of the controller output and the nominal solar panel wattage. But perhaps I should have qualified these are the generic voltages and I have now updated the post.
Bob , don't you mean 60a*14v 840 watts
You know you can't charge 12v battery with 12v,bit requires a voltage, above battery nominal full charge which is 12.6v,
A fully charged fla battery should read 13+v when charging is turn off
In that context what voltage would you suggest? 14.0, 14.4, 14.8, 56.0, 57.6, 59.2 or some other voltage which is dependent on the various mfg specs, not to mention that the voltage is also temperature dependent.
Or the commonly used terms of 12 or 48 volt battery systems. There is no one size fits all.
Jun-05-2021 11:30 AM
Jun-05-2021 11:08 AM
BobsYourUncle wrote:
Not a cheap venture at 4500 bucks for a battery! I'm sure the price will come down as more things like this become widespread in use.
Good stuff. 🙂
Jun-05-2021 09:09 AM
Jun-05-2021 07:49 AM
Jun-05-2021 06:17 AM
Jun-05-2021 04:30 AM
Jun-04-2021 09:16 PM
Jun-04-2021 07:09 PM
Jun-04-2021 07:06 PM
