What would you do??
Texas_Two_Stepp
Here is the situation. My friend wanted to downsize and be able to boondock camp so he went to a dealer and was sold a new Cardinal with a residential refrigerator, a 5K generator and 1-12v battery. He's going to pick it up in a week. I know there are all sorts of issues here. He didn't ask me anything and I'm not volunteering anything but know I will eventually be involved and will want to help. He will not want to spend much money. How's the best way to modify the rig so he can dry camp without running the generator all night? Oh, he also has a CPAP machine.
2015 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
24 REPLIES 24
mena661
MM49 wrote:
Your friend might be making the best move possible decision for dry camping. The most important feature is weight capacity for the battery bank. If you can carry the weight in the correct position on the rv the electrical design challenge can be solved. Every rv has its weight limits to how much battery bank can be carried. My rv is a TT and the most battery I can carry is two on the tongue. Any more and the vehicle stability is compromised. Motorhomes have it made with the weight carried between the axles.
MM49
Cardinal's are 5th wheels. There is no tongue. Also the shortest Cardinal is 35 ft and has a GVWR of 14,000 lbs. Weight is not an issue. If weight was an issue, wouldn't installing a big heavy house fridge and a 5kW generator be just as dumb? I had 400 lbs of batteries in my old 9500 lb GVWR 5th wheel. No stability issues or any issues of any sort. Why is there always someone here defending an obviously bad or uninformed decision?
westend
MM49
This assumes that batteries must always be carried on the tongue. With the advent of AGM, battery location isn't restricted to the outside of the TT, you can put them in any location.
I run a residential fridge (small dorm model) with 300AH and a single 235w panel. Average draw is about 40 AH/day. It can be done.
'03 F-250 4x4 CC
MM49
MM49
wa8yxm
There is only one choice...
To run the Fridge w/o generator, He will need an inverter, Likely 1,000 watt or more, and LOTS of batteries, I'd say 3 pair of GC-2 at the very minmum, likely more.
To run the PAP machine,,, He needs to make sure it can run on battery power and install the needed connectors near the bed.
or, Same inverter
But why dual convert (12 volt to 120 volt to 12 volt) if you don't have to.
He will also need to test the system to insure the batteries will last the night cause folks who use a PAP. if it looses power, can easily wake up dead. and that is not a good thing.
(I got,, Well lucky is not necessarly the word, but I was examined by both a cardiologist, who worked long and hard to keep me alive (clearly successfully) and a pulmanologist if I've spelled it right (lung and resperation) who did nothing for me but schedule a sleep study he felt I did not need.
The cardiologist and my Primary care, both based on the heart problems were sure I had severe Apena.
The sleep study results: NO APENA... None, Zip, Nada, Don't have it.
I told the sleep doc that I felt that if I were to make a bet, I'd bet on the Lung& Resperationb doctor. After all, it's his specality.
He said he'd have bet with the other two.
But no matter.. I WON.
Opie431
Do everyone else a favor and give us the name and location of the dealer so we all know who to avoid.
Francesca_Knowl
Seems like it's a bit late to "advise" your friend... Too bad you didn't come on here looking for info to pass along BEFORE he made his choice.
If you want to keep him as a friend, don't rub it in that he didn't do his homework!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
jaycocamper6230
Ummmm...Forest River is requiring 4- 6V batteries running an inverter on the Cedar Creek, I got one on order. Cardinal should be the same. I'd strongly question the dealer on that one
PawPaw_n_Gram
Buy him a very good ice chest for Christmas?
Full-Time 2014 - ????
“Not all who wander are lost.”
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
2oldman
IDman wrote:
Why is it always "a friend" who makes the mistakes?
LOL.. an apparently computer illiterate friend.
donn0128
UHHHH I think we are all missing something here. Forest River is not going to sell a RV with residential refer with only one battery. They will insist a minimum of two for a full hookup rig. I think the dealer is screwing your friend. Get him out of this deal. IT IS NOT A GOOD DEAL FOR HIM!!!!
To make that fiver ready to boon dock, he is going to want lots of solar panels, a decent charge controller and a very large battery bank.
midnightsadie
put him on to this site and let him read your post.
IDman
2oldman
Matt_Colie
It sure sounds like he bought the wrong rig for real boondocking....
As others have said, if he changes out the house bank for at least a pair of GC-2s and fits a 750W inverter, he can run both the CPAP and the reefer over night, but it will still take 4~6 hours of generator time to recover the house bank.
Give him our regrets.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
