where to buy panels and controller
98Evo
We are leaving Canada for Quartzsite/Palm Springs area soon. Is there still a good dealer and installer still in Q or would Cali be better?
thanks.
2009 Seneca
07 Harley Ultra
14 REPLIES 14
98Evo
thanks for the help gents. I have a pretty good idea of what I need now.
2009 Seneca
07 Harley Ultra
Lenny_K
The only thing that if you get an install done at Discount Solar in Quartzsite insist that your charge controller be set at 14.8 volts for absorption if you are using flooded cell batteries. So make sure that your charge controller has the capabilities of changing set points to enable 14.8 volts.
Discount Solar always insist that you use 14.4 volts which will never get your batteries properly charged.
Lenny and Ros
2009 Chevrolet Silverado 3500 LTZ Duramax 4x4 CC Dually, Banks Speed Brake
2012 Montana 3400 RL 680 Watts Solar, 440 Amps of Batteries, GP-ISW2000-12 Inverter, Trimetric 2020, EMSHW50C, Sailun Tires
Itinerant1
Yuma is a little further, as mentioned already Starlight Solar does installations. I also found Larry easy to work with explained what we wanted and how we use the 5th wheel and had a quality system installed. Been 18 months so far of continuous use. Can't complain and has exceeded expectations.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,500+ partial cycles.
corvettekent
You may want to check with AM solar in Springfield, OR
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
morley
If you have any inclination before going south to go to the west and buy in Canada it is very hard to beat Nova Independent Resources in Kelowna , BC for the most cost efficient and probably the best supply and installation of solar panels, controllers etc.
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
250 watt solar panel system, BlueSky controller and remote
Tom_M1
Sun Electronics has a Phoenix location. They have panels selling for about 50 cents a watt:
http://sunelec.com/home/
Here's some good info from Jack Mayer:
http://www.jackdanmayer.com/rv_electrical_and_solar.htm
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
Lwiddis
โ€œIs there still a good dealer and installer still in Q or would Cali be better?โ€
What have you decided regarding your solar system? Solar watts, type/capacity of controller and batteries? What did your energy audit show was needed plus a good reserve?
azrving
Discount solar has a nice showroom with a pretty good selection. I installed a second bank of three 160 watt panels from Solar Blvd and a second Bogart controller last winter. I was in Discount 3 or 4 times buying gadgets and talking misc solar stuff and they seemed like they are knowledgeable. I didnt inspect any of their installs but every time I go by there they are always working on rigs.
One of the key things is wire sizing as mentioned above. Any dealer can shoot prices and the more expensive one may be best if it's because he is sizing the wire large enough or even a little too large. As far as the Quartzsite area there may be others in the tent area or scattered out in the vendors but I dont know. I know that Discount isn't a flea market type place. They also employ a guy who can repair inverters so my measuring stick says that you may have a variety of employee capabilities but one of your main guys is smart enough to do complex electronic repairs.
So I have not seen their installs but if I wanted it done in Q I would go to Discount. If you are down by Yuma there is Starlight solar/Larry. I also bought parts from him when rewiring a friends undersized half azz system. He has a good selection and is knowledgeable. I haven't seen his installs but when I already knew what size wire I wanted I asked him and he suggested the same which was on the lager side. That's good.
The friend I helped had bought additional panels from Larry years before and Larry did recommend replacing all the wire yet my friends goofy know nothing camp buddies had kept telling him that you dont need big wire blah blah. Get some quotes and come back here.
Edit: Last year I paid $365 for three 160 watt Cynergy panels from Solar Blvd and that included $35 shipping from Norco Cali to the Outpost shipping center in the Q. I you have stuff shipped there be sure you are signed up for US mail or the postal system wot leave it at the Outpost. The panels were shipped UPS.
Another buddy who always has ants in his pants bought ONE 160 watt panel at Discount for about $260!!!
MEXICOWANDERER
The "license" would be a business license, or a special license where it would be easy to sort from unlicensed dealers?
harold1946
If you purchase from a licensed Arizona dealer there is no sales tax on solar equipment.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
2oldman
allen8106 wrote:
Do your research so you know what is required then force the installer to install it the way you want it.
x2. This is the way it should be done, but I don't think it is too often.
time2roll
You will not be too far from Norco CA.
https://www.solarblvd.com/products/
Best to order in advance for pick-up to make sure it is held in stock.
No installation services afaik. Probably have to buy equipment from the installer or their heart will not be in it. Anyway it is good to compare prices.
Chum_lee
Discount Solar in Q (no affiliation) has a pretty good inventory and knowledgeable staff but a lot of what happens on your particular rig depends on what you want done and the complexity of the job as well as who is available to do the work. Since you are in Canada, you are used to higher taxes. Q has some of the highest sales taxes in the country as well as California.
Do some research before you buy. Know what you want and what to expect before you buy. Often solar is a "sales oriented" purchase (rather than performance oriented) if you know what I mean.
Chum lee
allen8106
Might be some good "dealers" but doubt there are any good installers at Quartzsite. Most will undersize the wire which causes the uninformed to come back for more panels because they're not getting full potential out of the panels they have.
This is true of most installers anywhere. Do your research so you know what is required then force the installer to install it the way you want it.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
