Where to buy propane hose that connects
jimbo4UT
those little round propane tanks you can get at Lowe's or home depot or Walmart (20 pound tanks) to the motorhome tank. I know they are different connectors but without knowing the names I don't know where to look. Not talking about those 14 oz green ones for the grill but the bigger ones that are outside in a cage.
thanks in advance,
Jimbo
PS Just thought it would be nice to have that hose available incase I don't want to move but need some propane.
7 REPLIES 7
Flyfisherman128
Etrailer.com.. they carry Sturgis products.. higher quality
Bill_Satellite
The Extend-a-Stay product is all you need if you are looking for a simple backup plan.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
time2roll
Edd505
Most propane companies can make then any length while you wait.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Dutch_12078
This kit from Camco has the adapter and hoses needed to both connect an external DOT cylinder and any device that uses the small 1 lb throwaway cylinders like a grill or camp light. No additional regulator is needed since it connects to your existing ASME tank before the existing regulator.
Camco Propane Brass 4 Port Tee- Comes with 5ft and 12ft Hoses
Dutch
2001 GBM Landau 34' Class A
enblethen
On a MH, you can install a Extend-a-stay that allows you to connect an auxiliary propane tank.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
agesilaus
Amazon propane hoses
You will probably need a regulator too. Those small tanks are 20 lb propane takes.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
