Where to Find a Quality Set of Precision/Mini Screwdrivers?
Woodtroll
Hello, friends,
Like the topic says, I find myself in need of miniature screwdrivers more and more often, and sometimes the $3.99-a-set Harbor Freight ones make it hard to do precision work. Where would I find a decent set that would not chew up the screws I am working on? I don't need an extensive set, just a few very small flat and Phillips sizes. Thanks very much!
Regan
2003 F250XL 4WD 7.3L Crewcab LB, 6 speed; Prodigy brake controller; Big Tex grille guard/ deer deflector. Canoe hauler and camping truck extraordinaire!
2003 Layton 242 Scout- Extra batteries, solar panels, LED lighting, and propane for boondocking.
21 REPLIES 21
Woodtroll
Thanks very much, everyone, for taking the time to reply; I really do appreciate it! It looks like the Wiha tools are a good compromise between quality and my budget. I will give them a close look, but will check out the other options too.
Thanks again, safe travels!
Regan
Harvey51
https://www.ifixit.com/Store/Tools/54-Bit-Driver-Kit/IF145-022-1
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
MEXICOWANDERER
jwmll,
I have been infatuated with both those brands for a half century. Unfortunately I believe neither offer other than measurement hand tools any more. I have some B&S tungsten drills that outperform anything else I have ever used. Boy are those drills heavy!
Padlin
Went with the Wiha's too, used Specialty Tool.
Wiha Sets
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
jwmII
Locate a precision tool supplier and get a set of Starrett. Also checkout Brown and Sharpe. Both if they still have them might be a little pricey but you will never need to buy them again.
jwmII
westend
Another good source for hand tools--Vessel
'03 F-250 4x4 CC
SCVJeff
Harbor Freight and Quality are contradictory words.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
isa
I got mine at Harbor Freight.
MEXICOWANDERER
Wiha also sells driver screwdriver tips for battery or corded tools. Truly improved bit life. Their diamond coated tips really help to reduce cam-out (stripping of the head)
SCVJeff
Buy the Best and Cry Only Once
WIHA is the standard of high quality precision drivers
Jeff - WA6EQU
MEXICOWANDERER
A BAD TECHNICIAN BLAMES HIS TOOLS
I must be terrible. I ended up choosing Wiha which I consider to be the best quality small size screwdriver in the world. Missing in the set, below, is 000 Phillips which is all-too-common these days.
Wiha is made in Germany and the tips last longer than anything else I have ever used.
http://www.ebay.com/itm/Wiha-26190-Precision-7Pc-Set-Phillips-00-0-1-Slotted-1-5-3mm-Bonus-Pack-With...
FLUSH CUTTERS. Good to 16 gauge but really designed for board work. These Hakko flush cutters are about the best I have ever used. Don't let the low price fool you, these critters run circles around Klein cutters that sell for much more.
https://www.sparkfun.com/products/11952
MrWizard
Moderator
Moderator
i bought a precision set for working on cellphones and such devices
from Fry's electronics i think it was $12
i have two other sets, i bought at home depot for around $10 each
I can explain it to you.
1997 F53 Bounder 36s
obgraham
The little blue Kobalt set sold at Lowes is great. Interchangeable tips all store in the handle. Good quality tips that will grip the screw well and not get chewed up. Under $10.
K_Charles
X3 on the hobby shop.
