whirlpool washer balance
badboy368
I just installed a brand new whirlpool stackable washer and dryer. I am happy with the performance of both so far, but the washer literally shakes the entire coach when spinning. Has anyone ever experienced this or know what i can do to maybe balance this machine? Or maybe point me in the right direction to solve this?
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
13 REPLIES 13
badboy368
got it.....thank you very much. i will look at that today.
dougrainer
ALL Clothes washers have 4 Shipping bolts to secure the drum in transit. IF you read the Install directions it is pointed out to remove those bolts:B Doug
https://producthelp.maytag.com/Laundry/Washers/Product_Info/Washer_Installation_Support/Moving_a_Fro...
https://producthelp.maytag.com/Laundry/Washers/Front_Load_Washers/Noise_and_Vibration/Vibration%2C_W...
badboy368
Hi Doug, Maybe I don't remember removing those bolts..:h... can you give me a little more info?
Cummins12V98
dougrainer wrote:
Did you REMOVE the drum shipping bolts? Forgetting these usually causes your problem. Doug
I resemble that remark.......
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
dougrainer
RJsfishin
you doing too big a loads Make them smaller then its easier to distribute the load evenly
Rich
badboy368
coach is definitely level, and washer is level also. i will try pausing the cycle and rearranging load to see if that helps. this surely has me puzzled. Please keep any other ideas coming
Cummins12V98
coolmom42 wrote:
Cummins12V98 wrote:
That’s what they do. “L” clip it to the floor.
That assumes the floor is level. It's not a good idea to transfer all that vibration stress to the floor.
That is exactly how both my washer and dryer were installed at DRV.
coolmom42
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Cummins12V98
wa8yxm
The washer empty will not shake.> but even my mini can really shake things up (1.6 CU-Ft does bedding by the Johnny Cash Method "One Sheet at a Time" 🙂 )
re-arrange cloths and re-start spin cycle.. You may need to do this a few times.
coolmom42
Make sure the coach is level and the washer is level in the coach.
opnspaces
Navigator II
Navigator II
When my home washer does this I pause the washer and redistribute the load around so it's more uniform.
