Why did my water pump stop pumping?
traildog
Hello!
On the way to our campsite, we used the pump several times.
Got all set up and turned on the pump and it runs but won’t pump.
All fittingsare tight, tank is full but no water is pumping.
Could it have lost its prime?
Thanks
TD
2021 Coachmen Freedom Express Ultra Lite 259FKDS.
2021 Ford F-150 3.5 ECO BOOST 4:30
29 REPLIES 29
traildog
Wait until I upload a picture of where the pump is located. I’m going to need to cut an access hole or drop the power panel to get to it.
wa8yxm
Yup if you have plenty of water and there is a crack in the inlet side of the pump or the hose feeding it.. It can suck air once the water level drops below the level of the pump.. Many forget to empty the inlet strainer in the fall.
There may be a shut off valve.
The outlet strainer on the tank can clog (inlet strainers almost never clog because they are secondary to the outlet but .. it's not impossible)
Pump can fail in assorted ways.
And last... Did you VISUALLY verify water in the tank or trust the @Q#$#@ sensor panel?
C_Schomer
Deja vu… mine did that a few years ago. Suddenly no pumping and I’ll be dipped if I could find the problem at the CG with the general tools I had. It was the brass pex fitting at the pump inlet got a tiny crack in it. I got home and replaced it with a genuine plastic fitting and have not had any more problems. ANY tiny leak on the suction side will break the prime!
FWIW, I discovered an internal strainer at the water outlet of my water tank and I didn’t want to take a chance of that thing clogging up someday. I used a drill bit to get a hold of the strainer and it slid right out and then I put a strainer at the pump inlet. When I had my pumping problem I figured it was an air leak at that strainer but, hail no, it couldn’t be that simple.
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
opnspaces
Navigator II
Navigator II
Go a step beyond just turning on the faucet. Unscrew the aerator out of the end of the faucet. Turn the faucet on and and let the pump run.
Esacnj
look here
Esacnj
way2roll
Navigator
Navigator
Clogged screen, winterization valves or fuse is where I would start.
Jeff - 2023 FR Sunseeker 2400B MBS
MFL
Nomad II
Nomad II
wolfe10 wrote:
Open a faucet. If there is an air pocket, that will aid in bleeding the air out.
If that doesn't work, open the kitchen sink faucet, and with the pump turned on, suck on the faucet. That will, as above, help bleed the air past the pump.
I agree with the first part, but that sucking the faucet, should not be necessary, unless a roach is trapped in the line.
Also don't be afraid to let the pump run dry for a bit, waiting for it to prime. It will not harm it.
Jerry
schlep1967
Check your settings in the wet bay. You may be feeding water from the tank to the tank.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
traildog
midnightsadie wrote:
check fuse. if your reading the empty/full gauge? they are not very good at telling the true water left in the tank.
Pump runs but doesn’t pump.
traildog
pianotuna wrote:
How old? What make and model of pump?
Camper is 2 years old. I looked at the pump but I’ll have to get the make and model later today.
traildog
schlep1967 wrote:
Pump is self priming. How did you verify the tank is full?
I pulled the drain, let some of the water out and then refilled it. It’s full.
midnightsadie
pianotuna
Nomad III
Nomad III
Regards, Don
schlep1967
