May-02-2022 08:16 PM
May-03-2022 06:34 PM
Gdetrailer wrote:I agree with this
Instead, opt for a $8 12V relay which the coil is connected to the ignition keyed source which is powered only when engine is running.
Common 12V relays are the "Bosch" cube style which are typically 30/40A which would be enough to cover the charge fuse.
For overkill they do make a 70A Bosch style relay..
May-03-2022 03:32 PM
May-03-2022 11:24 AM
May-03-2022 09:12 AM
fr500c wrote:BFL13 wrote:
Just pull Stud 1 fuse under hood
https://www.google.com/amp/s/www.autogenius.info/gmc-sierra-mk1-1996-1998-fuse-box-diagram/amp/
I can’t seem to locate stud 1. Feeling like a real idiot at the moment!
May-03-2022 08:31 AM
May-03-2022 06:44 AM
Bud
USAF Retired
Pace Arrow
May-03-2022 05:43 AM
BurbMan wrote:
You do want some type of battery isolator like this one so that when the truck is running you'll charge the camper battery. Pulling the stud 1 fuse will prevent the camper from draining the truck battery but will also prevent the truck battery frm charging the camper battery.
The isolator can be anywhere between the two batteries, either under the hood, under the the bed or in the camper. My 2002 Lance had one under the sink where the 7-pin cord came inside.
May-03-2022 04:40 AM
May-02-2022 11:28 PM
May-02-2022 10:54 PM
May-02-2022 09:15 PM
May-02-2022 09:10 PM
