โDec-09-2019 09:09 AM
โDec-10-2019 07:41 AM
Bobbo wrote:jfak7670 wrote:
Not so long ago I bought a new Yamaha EF2000iSv2 generator. Maybe someone has already had an experience with this gen and can suggest how many appliances can I run with it?
About 12 or 13 amps. You have to add up the amp draw for each appliance. If the batteries are low, the converter/charger may take up most or all of that.
I have the 2000 watt Honda. It is dedicated to charging low batteries, and nothing else. Everything else is on propane. No microwave while batteries are charging. No hair dryer while batteries are charging.
โDec-10-2019 04:50 AM
โDec-09-2019 07:11 PM
โDec-09-2019 06:03 PM
โDec-09-2019 05:21 PM
โDec-09-2019 01:49 PM
theoldwizard1 wrote:Yes it is, close to running the air.
That microwave is probably pushing the capacity of that generator..
โDec-09-2019 01:14 PM
โDec-09-2019 12:57 PM
โDec-09-2019 12:50 PM
โDec-09-2019 12:36 PM
midnightsadie wrote:get another and parallel them.
get a bigger gen set.
โDec-09-2019 12:35 PM
โDec-09-2019 12:27 PM
โDec-09-2019 11:54 AM
โDec-09-2019 11:41 AM
road-runner wrote:time2roll wrote:This is the likely answer and a good voltage measurement is the only way to know for sure. The eu2000i voltage goes down to about 110 when it's heavily loaded. If your shore power is a solid 120 volts or higher, you'll see and hear the difference. It's easy to mistakenly think there aren't any other loads on the generator when there really are. Fridge and converter are the common culprits. A 1000 watt microwave pulls close to the rated load of a 2000 VA generator. If there are any other AC loads, high ambient temperature, or high altitude involved, an additional load will push the generator close to or over it's shutdown threshold. When the generator is heavily loaded, the only thing the eco switch will do is enhance the probability of the load device starting up. Once it's running, the eco switch does nothing.
Voltage does sag a bit toward maximum output on these generators.
โDec-09-2019 10:55 AM
