zeb vs UV
danskool
Good afternoon.
Seeing the zeb floor sealer has 5 million threads and pulled lots of attention on shining up rv's. What worries me and the reason I won't try it as of yet is It has no UV protection.
My Question is, Won't outdoor patio sealer do the same thing and will be UV resistant? Anyone try that? like a water based sealant like "clear-seal" from depot. I use that stuff on my walks and patios and it is amazing how shiny it is and holds up well even with shoveling snow and ice.
Just always wondered if I should do a science experiment.
Dan
2021 5th Wheel Crusader 29RS
2001 F250 XLT 7.3 PSD
26 REPLIES 26
hone_eagle
Zep makes a remover /stripper ,I had to redo the front cap -eazy pezy
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
B_O__Plenty
My Zep coating started to crystalize after being in the Sun for a year. It was hard to get off and required some scrubbing with stripper. I ended up painting it.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
larry_barnhart
From experience the red max pro #3 is a tough job to remove. I will not recommend using Zep or red max pro #3 if it is still on the market. Doing a couple of poli glow applications at this time. No more waxing for this 75 year old youngster.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
avvidclif1
Read up on Rejex.
Clif & Millie
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2015 Heartland Cyclone HD CY3418 Toy Hauler
Bumpyroad
well from these "testimonials" I am pleased with my decision to deep 6 the stuff. might be great to put a coat on if you are trying to sell a unit however.
bumpy
Ed9824v
mine never yellowed but the side facing the sun has signs of going bad after one year. So I did the whole 5er in 303 Aerospace Protectant and hope that will help to give it some UV protection. Will keep an eye on it.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
brirene
N-Trouble wrote:
Zep/Red Max Pro looks great after you put it on but reportedly will yellow after a few years and is difficult to remove.
Mine didn't, and wasn't. After several years of not doing the refresher coat as suggested, I decided to strip what was left from the front cap and do again. Old stuff came off with the BK Friend, 4 new costs have it looking great again. After stripping the old off, the original cap color was identical to the side with the old Zep (actually Red Max Pro). I was surprised it hadn't yellowed at all. Was actually easier than I had anticipated.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
keymastr
Poliglow will eventually fail as well. Yellows and cracks. It works great for bringing back very neglected gel coat but if your unit has just some mild oxidation I would not use it.
It will breathe new life into a basket case though.
N-Trouble
Zep/Red Max Pro looks great after you put it on but reportedly will yellow after a few years and is difficult to remove. Recommendations are to use Poli-Glow instead as it has UV protection as well and reportedly wont yellow. This is what I have read. No first hand experience.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Bumpyroad
I bought some, considered using it, read the troubles removing the old, and still have a jug someplace.
bumpy
gbopp
I vote for the science experiment. Just do a small section and see how it works.
I always tell people to do the Zep/Red Max Pro process and then use the wax of their choice. Preping the surface is the critical part of the process.
Ed9824v
my Zep only lasted about 3 yrs. then I redid it, wonder if 303 Aerospace Protectant would work and be uv protection
Ed So.Calif
