โMay-22-2016 02:06 PM
โMay-29-2016 09:54 AM
therink wrote:
That is the reason SRW 1 ton trucks don't have the 20" wheel option available. I recommend going with 18" wheels and load rage E tires. The stock Michelin 265/70R18's on my one ton are rated for 3525 lbs.
I'm sure you know but no matter what you do with tires, it will not increase the load carrying capacity of the truck. That is a lot of weight for a 3/4 ton.
โMay-29-2016 04:56 AM
โMay-24-2016 01:30 PM
โMay-23-2016 01:29 PM
gmcsmoke wrote:
according to michelin the tires are not the limiting factor (3,195 each). what's the unloaded rear axle weight?
โMay-23-2016 01:13 PM
โMay-23-2016 11:38 AM
โMay-23-2016 10:36 AM
โMay-22-2016 09:04 PM
โMay-22-2016 06:34 PM
โMay-22-2016 05:17 PM
โMay-22-2016 04:50 PM
โMay-22-2016 03:44 PM
โJun-10-2024 08:27 AM
The new trucks with 20" tires have 3750 capacity now
โJul-25-2024 05:25 PM
adding to way2roll 3750 is just the rating of one brand of tire, my 2014 f350 came with tires rated for 4078lbs, it all depends on the size of tire.
