May-22-2016 02:06 PM
Aug-01-2024 05:29 PM
what kind of tires were they?
Jun-11-2024 05:52 AM
Ignoring that you are replying to an 8 year old thread, this statement is really generalized. While tires do play a factor in payload, not all trucks have as much payload as you stated. There are a LOT of other factors not the least of which is the model of the truck itself.
Jul-25-2024 10:37 AM
I was answering the question asked about higher capacity 20" tires, was not trying to be the tow police slamming his quest for a tire that gave him a bigger safety margin. All Ford SuperDuty& GM HD trucks currently use the 20" Tires with tbe 3750 rating. I answered his question. If you want to criticize people at least know what you're talking about!
Jul-25-2024 11:02 AM
I am sure the OP would appreciate your input - if you had a time machine that went back 8 years.
Aug-01-2024 05:31 PM
These forums are looked for years by people looking for information. Please find someone else to harass! Have a wonderful day!
Jun-25-2024 07:35 PM
ignoring your ignoring response lol, although it's 8 years later some of us are still looking for the highest load rated tire we can get for added safety while having a heavy truck camper. If my trucks rated for 7k rear axle capacity I would want 10k capacity if available, even if my rear axle weight was 6k.
Jul-26-2024 05:18 PM
so make it relivent and start a new thread. there are so many new brands and models of tires out now than there were 8,9,10 years ago.
May-22-2016 03:15 PM
May-22-2016 03:02 PM
May-22-2016 02:59 PM
Second Chance wrote:
I posted this on the Silverado/Sierra forum and got one response... "good luck." Since folks on this forum are more into towing than jacking trucks up to make them look macho, I'll see if anyone here knows of anything:
My wife and I are full-time RVers. Our truck is a 2013 Sierra 2500HD SLT CC D/A with the 20" wheel option. While the 20" alloy wheels look very nice, I'm having trouble finding a higher capacity tire than the stock LT265/60R20 load range Es that came on the truck. I'm looking for input on either: 1) load range F tires in the LT265/60R20 size, or 2) suggestions for replacement wheels in a size where load range F tires would be available without changing the outside diameter of the tire/wheel combo (currently 32.5"). I'm happy with the current gear ratio and the performance of the D/A when pulling our house-on-wheels. I could tolerate a slightly smaller diameter, but not anything larger (wouldn't mind a few more RPMs at cruise where the tranny would shift into 6th a little sooner).
The pin weight on our fiver as currently loaded is right at 3,000# which puts us just barely under the rear axle rating (GAWRR) for the truck when pulled across the scales (verified both on CAT scales and a wheel-by-wheel weight system proprietary to one of our RV clubs). The total capacity of the tires is a few hundred pounds above the axle rating, but I'd still like to increase that safety margin. I understand that no aftermarket modification (tires, air bags, etc.) can/will increase the ratings of the truck... it is what it is. I'm just looking to increase the safety margin on the most likely thing to fail.
