I'm curious to know what you would do?
4x4ord
I am replacing my 2022 F350 Platinum with 26000 miles. I can replace it with an identical truck .... 9 months newer and 1/2 the mileage for $4000 difference .... or, for $14,500 (CAD) difference I can pick up a new 2023 high output Platinum that I ordered months ago that has finally come in.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
91 REPLIES 91
Lantley
'm not saying the GVW numbers are the most critical parameters known to man.
But only RV.net engineers would go as far as to claim they are fabricated.
As always, the RV.net mantra is "If the parameters don't work for you or comply to your scenario criticize and ignore them as if they never existed."
19'Duramax w/hips, 2022 Alliance Paradigm 390MP >BD3,r,22" Blackstone
r,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,Prog.50A surge ,Hughes autoformer
Porta Bote 8.0 Nissan, Sailun S637
spoon059
Yup, all those numbers are fabricated, without a doubt. I'm researching a XLT or Lariat trim, longbed Crewcab, either 7.3 or 6.7.
2015 Ram CTD
2015 Jayco 29QBS
4x4ord
spoon059 wrote:
So in theory, over 4000 lbs payload are possible, especially with lower lower trim levels. Those are pretty good numbers.
The payload rating is kind of a fabricated number in my opinion. I think the lower trim levels and or lighter engine options have lower GVWR numbers. I think you can get a little over 4000 lbs payload but not a whole bunch. (Get a lariat to get the 20โ€ wheels but no sun roof for instance) I believe you need the long bed, the 20โ€ wheels and the diesel engine to get the 12400 gvwr.
As an example of why I think the payload numbers are kind of fabricated take a look at my shortbox. It has the same strength frame, the same wheels/tires/brakes and the same suspension as a long box. So it certainly isnโ€™t going to hurt anything for me to load my truck as though I have the same 12400 lb gvwr as the long box. And because the short box is probably about 200 lbs lighter than the long box โ€ฆ.. one could argue the shortbox should be able to carry a couple hundred lbs more than the long bedโ€ฆ.. Although even if my shortbox had a 12400 gvwr it still wouldnโ€™t be able to handle as heavy of pin as the long box. (The long box has less weight on its rear axle when empty)
B&W Companion
My 2020 Platinum 350 SRW long bed has 4000# capacity. 12,400# gvw
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
spoon059
2015 Ram CTD
2015 Jayco 29QBS
4x4ord
^^^You are correct. I think the diesel F350 crew cab long box with 20โ€ wheels has a gvwr of 12400 lbs. The diesel long box super cab with 20โ€ rims is 12300 lbs. Iโ€™m pretty sure all the 4x4 F350 diesels have the same rear springs and axle โ€ฆ.. the longer wheel base puts less weight on the rear suspension which I think is why the give a little greater gvwr to the longer wheel base trucks.
B&W Companion
spoon059
4x4ord wrote:
The โ€˜23 is 12000 lbs and the โ€˜22 11500 lbs. Both have rear axle ratings of 7230 lbs โ€ฆ. so, really, as far as Iโ€™m concerned they can both handle the same payload anyway.
Since you are the expert, am I correct in understanding that there are SRW 350s with a 12,400 GVWR?
2015 Ram CTD
2015 Jayco 29QBS
4x4ord
B&W Companion
spoon059
4x4ord wrote:
Another surprise is that this one has a 3828 lb payload capacity .... not bad for a 4x4 diesel crew cab fully loaded SRW short box (my 2022 only had a rated payload of 3270 lbs. I look forward to towing with it but it's possible the '24 will be in before I get a chance to try this one out. ๐Ÿ˜‰
What is the GVWR?
2015 Ram CTD
2015 Jayco 29QBS
ksss
LOL! You kill me! I think I suggested just getting a '24 to start with. My '24 is in and I pick it up in a couple days.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
4x4ord
I hooked it up to the fiver and discovered that the electric over hydraulic setting for the hydraulic disc trailer brakes on the new truck is compatible with my trailer ... my 2022 wasn't, so that's a bonus. This is the first vehicle I've had with HUD ... I like it. Lane centering is not what I hoped for. I think the seat was more comfortable in the old one but maybe I just have to get it adjusted right. The tech is definitely an improvement. The sound system is amazing. Another surprise is that this one has a 3828 lb payload capacity .... not bad for a 4x4 diesel crew cab fully loaded SRW short box (my 2022 only had a rated payload of 3270 lbs. I look forward to towing with it but it's possible the '24 will be in before I get a chance to try this one out. ๐Ÿ˜‰
B&W Companion
Me_Again
I am glad I have my last truck, because the prices today are crazy high. I got 9500 off when I bought my 2015 Ram 3500 4x4 Laramie in Sept 2015. And I got 2K off the 2021 F150 and more than I paid for the 2020 Edge ST we had bought 15 months earlier as a trade in.
MFL
Nomad II
Nomad II
FishOnOne wrote:
Cummins12V98 wrote:
If you can afford it and I know you can, buy what you want plain and simple!
Well said...
Yup...pretty much what I said on first page.
It's all about your personal budget/spendable wealth. If spending an additional 10K is going to cause you to stay home, not afford fuel, or enjoy doing fun things, keep whatcha got.
No one wants to get bent over, but seems a good price being offered on the new truck!
Jerry
FishOnOne
Well said...
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
