โApr-23-2015 12:04 PM
โApr-27-2015 02:55 PM
โApr-27-2015 12:09 PM
โApr-27-2015 09:15 AM
โApr-27-2015 09:04 AM
Boatycall wrote:
One thing I will say about these, coupled with the controller I chose-- Low light performance-- IMHO....OMG, I swear, these things put out a charge with a flashlight. This morning I went out, 8am here in Seattle, completely overcast, and I was already getting 3amps of charge.
โApr-27-2015 08:39 AM
bka0721 wrote:
1. Impossible to remove if need of replacing.
2. Heat from panels and heat from surface (metal) combines to heat the panels even more.
3. Heat clips off amps generated with all solar during warmer months but at a higher rate/sooner with these panels and shortening the period of solar harvesting for the day.
4. Shorter Lifespan from glass panels
5. Cupping is created across the cell.
6. Dirt and Debris Collect in the concave of the cupping.
7. Cupping requires additional cleaning and care for flat panels
8. Due to the panel being polymer, they are not resistant to scratching when cleaned.
9. Marring of surface decreases the capabilities of solar collection.
โApr-26-2015 11:00 PM
โApr-26-2015 09:42 PM
โApr-26-2015 07:27 PM
pianotuna wrote:Hi Don!
Hi B,
Cupping is not an issue with Unisolar. It is with some other companies.
It is true that Unsolar requires a huge area of roof space, but it is also true that their low light performance is better than most other panels.
I may end up starting over because I now want a lot more watts to be available per square foot of panel.
โApr-26-2015 05:52 PM
โApr-26-2015 05:07 PM
Boatycall wrote:Sorry, haven't been back for a while. It is always good to see others and their discussions too.tony lee wrote:bka0721 wrote:
2 different parties that I know opted for this type of solar and after a year's use have discontinued their use, opting to return to the standard glass surfaced panels.
Why?
I'm very curious also... why? Is there something I should know? I mean, I'm recommending this setup to others I know, so if there's something up with them I'd take it as very good advice.
โApr-25-2015 12:00 AM
โApr-24-2015 09:10 PM
Why?
โApr-24-2015 08:17 PM
โApr-24-2015 07:57 PM
Why?
