โJun-13-2014 10:34 AM
โJun-23-2014 03:04 PM
โJun-23-2014 02:00 PM
deltabravo wrote:
I have been using my brothers 450p. I'm pretty impressed with it.
Here: Viair 450P
โJun-23-2014 01:31 PM
โJun-23-2014 08:15 AM
โJun-23-2014 05:29 AM
โJun-22-2014 09:36 PM
โJun-21-2014 11:15 PM
โJun-20-2014 08:56 PM
โJun-20-2014 05:00 PM
pa traveler wrote:
Does VIAIR 450 have an attachment to fill inside duallys?
โJun-15-2014 04:55 AM
zman-az wrote:
110vac has nothing to do with it. Is a all about the pump and the motor to run it.
If you really want a portable air compressor you want this. Oasis
And if you are cheap and creative you can pull that pump out of a 80's AMC Eagle and hook it up with a belt to your current automotive engine to power it. I did all this for under $100 to a jeep I had. You really can run a impact gun off of it without a air tank.
โJun-14-2014 09:48 PM
โJun-14-2014 03:18 PM
anutami wrote:RoyB wrote:
Back in my JEEP running days we was always bleeding down the tires for better traction.
I have been using the 12VDC tankless portable air compressor. It may not be the fastest one in the world but airs up my trailer and truck tires and all the kids bicycles at the camp grounds...
This is the Q Industries portable MV50 12VDC 150 PSI Air Compressor available from AMAZON. It fits in its nice carry bag under my truck back seat. I usually sit this on my truck tailgate and hook into the trailer batteries and then I can use the provided long air coil hose to walk around the trailer and tires...
I also use this air compressor along with the CAMCO 36153 Blow Out Adaptor to blow out my water lines for winterizing. Being TANKLESS it takes more time to build up air compressor which is ideal for blowing out water lines.
Perfect setup for me and my OFF-ROAD POPUP trailer.
Roy Ken
I use this as well for my F350. From usually 35-55 air down to 65-80 air up. Takes 4 to 5 minutes per tire. The gauge is Inaccurate. I would not recommend it if you're going from 18 psi to 80 though. You're probably looking at 8-10minutes per tire, And it gets really hot. But it is cheap, Maybe buy two of them. It did get the best reviews out of the lower end air compressors.
โJun-14-2014 11:53 AM
โJun-14-2014 11:00 AM
